Tractor Talk Discussion Forum
Valve Tappet
Tweeter
12-17-2003 19:28:02
I checked and made sure that the tappet clearance for all 4 valves were correct in my Briggs 16Hp twin. They are all within the specs in the repair manual. The engine has a loud tap now when I got it started. I do not understand. Was the tap created by the clearance or something else?
wdTom
12-19-2003 18:26:39
 Re: Valve Tappet in reply to Tweeter, 12-17-2003 19:28:02
If you can, insert a feeler gauge into the gap when the engine is running, see which one gets quiet when you do. this is the problem one. Look for the problem. Worn parts, not set at proper rotation of engine, sticking valve maybe.
Ben in KY
12-18-2003 11:27:49
Does the engine have hydraulic lifters ? Some do and I have heard that they ( Kohlers in particular) are sensitive to the oil used.
Tom
12-18-2003 06:24:26
Tweeter, re-check your settings. Maybe you did not have the engine turned to the proper point when you adjusted one of them?
RAB
12-17-2003 22:54:06
Might depend on how they are set. Using a feeler guage doesn't take into account any wear on the components. A dial guage might be needed or repair /replacement of any worn components.
Regards, RAB
Ray,IN
12-17-2003 19:38:08
The first place to check is to reset the clearences. Did you reset them after a through warmup also? I've seen this happen and found that one pushrod was not seated when the valves were adjusted too.
Tweeter
12-17-2003 19:44:30
 Re: Re: Valve Tappet in reply to Ray,IN, 12-17-2003 19:38:08
It said in the repair manual to adjust the clearance while COLD.
