Tractor Talk Discussion Forum
MASSEY FERGUSON BACKHOE UNIT
BILL
01-14-2004 20:15:42
I need help identifying a MF backhoe unit which has 4 point hook-up It came with an oliver oc 46 I bought The id tag is tore-up but has model 22 for sure then what I think is 28 but tear is in that area serial number is 5335 has 6 levers used crawler hydrolic source Out riggers go straight down at about 7 feet wide Any help with proper model number will be appreciated as I wish to list it for sale but really need model
rod
01-16-2004 04:15:57
 Re: MASSEY FERGUSON BACKHOE UNIT in reply to BILL, 01-14-2004 20:15:42
I have the operators manual and the parts book for the MF 220 if anyone needs pics or copies drop me an email at rodswinamer@ns.sympatico.ca
regards
rod
donm
01-15-2004 09:22:10
Is the 6 lever control a solid casting or a segmented type with thru bolts? Does the swing cylinder have standard hydr. cyls, or is it a rotary style actuator? If solid valve and rotary, could be a Davis hoe, sold by MF early before they made their own. I have one of these.
rod
01-15-2004 04:35:12
could be a MF 220 seat sits on top of swing motor I have one and it works pretty good after lots of work on it they fit lots of tractors MF 35 MF 65 all of the 200 series like 202 203 204 205 industrials and also the 300 series. regards
rod
550Doug
01-15-2004 06:31:52
 Re: Re: MASSEY FERGUSON BACKHOE UNIT in reply to rod, 01-15-2004 04:35:12
I'd like to see some pictures of Bill's backhoe, as well as Rod's MF220. I too have a backhoe that I cannot identify. It is on my 1967 Cockshutt550/Oliver550 indust/White2-44LL tractor and it needs some work on its hyd control box. It too has 4 pt hookup and vertical outriggers.
Thanks
bill
01-15-2004 12:15:24
 Re: Re: Re: MASSEY FERGUSON BACKHOE UNIT in reply to 550Doug, 01-15-2004 06:31:52
I do not kow how to put pict on this site however if you will e mail me I can send pictures
550Doug
01-15-2004 14:12:01
 Re: Re: Re: Re: MASSEY FERGUSON BACKHOE UNIT in reply to bill, 01-15-2004 12:15:24
How do I get your email address from your post??
Here is my email so you can send me some pics
dgminke@eudoramail.com
Thanks
