Tractor Talk Discussion Forum
How can you tell an F20 from an F30 ??
Mark Lahner
03-15-2004 09:17:16
I know this is really stupid, but I know nothing about F20's. I recently "bought" one to restore. It needs an engine overhaul, gastank, seat, manifold. (It cost me 2 cases of beer.)I am looking at a parts tractor (no engine) to use to restore it, but the guy selling it does not know if it is an F20 and I have not yet seen it. Can I tell from the nameplate? I know the F30 is bigger, but that is all I know. Any help? Thanks.
Nebraska Cowman
03-15-2004 10:25:53
 Re: How can you tell an F20 from an F30 ?? in reply to Mark Lahner, 03-15-2004 09:17:16
On a 20 the PTO lever is down low on the left hand side. on a 30 it is a rather large lever beside the gear shift. Also the rear axle has a large nut on the end that is not present on the 20. 30 has a water pump, 20 does not. clutch pedal is adjustable on the 30, belt bulley drive is bolted on with 6 bolts, 20 has 4.
Bobcat
03-15-2004 16:24:08
 Re: Re: How can you tell an F20 from an F30 ?? in reply to Nebraska Cowman, 03-15-2004 10:25:53
Just one or two more differences. F-20 has 1 bellhousing bolt connecting to frame rail where the F-30 has 2. F-20 oil filter toward back of engine F-30's right in middle.
Bill Smith
03-15-2004 09:52:28
I agree with Jed. Easiest way to tell by appearance is to look at gas tank. F-30 gas tank from the side looks to be square and the F-20 more rectangular. Since you are missing the tank you might just have to go by serial number plate. I believe the F-30 is noticeably taller from frame to the top of hood. Wheel's I believe about the same size but the F-30 a little larger in scale. Check out some photos under tractor photos on this site. 2 cases of bear sounds cheap enough.
jed
03-15-2004 09:36:48
The serial plate on the tool box should tell you. Also the gasoline tank on the F30 is a huge square affair compared to the one on the F20. Size wise they are almost indentical.
