Tractor Talk Discussion Forum
Kinda OT, But how much gravel do I need?
Matt
03-25-2004 16:23:15
I have a driveway that is 210 feet long. It is bare dirt as this is a new house. I will need a small place to turn around, as well. I think crusher run is the standard for driveways now, isn't it? How many tons will it take if I want a 3-4 inch thickness? The driveway will be as wide as the bed of the dump truck.
EngineerJoyce
03-26-2004 06:40:00
 Re: Kinda OT, But how much gravel do I need? in reply to Matt, 03-25-2004 16:23:15
Okay. good points all. Without knowing definitively the soil type, subsurface, and local variables, I cannot give a fully evaluated legal professional opinion.
so let's do that. My email is linked. Send me your details and I will give you a professional analysis.
I am a licensed Professional Engineer in the state of Kentucky and work for the federal government as an Agricultural Engineer for the USDA - Natural Resources Conservation Service. Try me.
Kirk Grau
03-29-2004 06:28:16
 Re: Re: Kinda OT, But how much gravel do I need? in reply to EngineerJoyce, 03-26-2004 06:40:00
OK, I am getting to this a little late.
Our situation 1:
15 acre horse farmette purchased 1.5 years ago. Clay soil that could be used to line a pond. Water can sit for days in some of the local low spots in the pasture. Located a 100' X 200' grass riding arena (just fenced the pasture and started mowing) at the highest, best drained spot on the property. Of course grass getting beat up and arena is turning to clay. Want to improve footing. Considering stripping the top 6" of soil and laying a GEOTEX fabric, 6" of something that will roll down good and hard, 3-4" of "pea" gravel for drainage, topped by 2-4" of a washed sand. I am proposing containing the added height with Railroad ties or treated lumber at the base of the existing fence. Will the GEOTEX help out at all in this situation (ie is it worth the investment here)?
Situation 2:
Lowest spot on the front half of the property is 50' from the barn and the horses have to go through it everyday to get to the pasture. Last year (wet as it was) this spot was probably dry for a total of 10 days. Considering stripping this down, (when it dries again) laying geotex, filling up with screenings to make a nice lane to walk the horses out.
Are either of these situations appropriate for the GEOTEX?
Am also looking at drain tile to try to take the water away from the low spot, but the cost is looking kind of prohibitive considering the next spot that is any lower is almost 1000' away and would require trenching through the afore mentioned high spot making a trench about 10-14' deep at that point to make fall for drainage. I don't mind spending the money if it helps make the place livable, but obviously I would like to keep it to a minimum.
Any other ideas also welcomed.
TIA,
Kirk
Mark
03-26-2004 07:53:12
Yipes guys. Watch what you say, big brother (sister) is watching. LOL.
Seriously, Joyce, nice to meet you and congratulations on your accomplishments. I know you have worked long and hard to achieve your professional goals and we are proud to chat with you.
Thanks for being helpful to those of us who didn't pay the price.
Mark
gene b
03-26-2004 04:54:28
ONE cu.yd. will lay 81sq ft 4in deep. Your driver and local supplier of rock will be your best source of information as they do it all the time. Just give them a call they will be more than glad to help. We dont know your soil types and other details as well as they would. AVG wt of one cu.yd is around 2800 lbs according to the man on the scale at local quarry.
KURT
03-26-2004 01:47:44
Do this and you will not regret it. 1. hire an excavator to remove the top 6 inches of topsoil. 2. lay in 3" of fill sand. 3. lay in 3" of large 1X3 limestone. 4. lay 3" of 21AA gravel. This is exactly what I did and I dont regret it one bit. My driveway is tough as nails and will hold up to 80,000lb concrete trucks. As for gravel and sand amounts for a 12' wide drive you will need the following for what I described. 40 yards of fill sand, 40 yards of 1x3 limestone and 40 yards of 21aa gravel. in my area this would cost about $2400 for the material and guy with a front end loader backhoe for a day. which would be about $500. DONT USE THE FABRIC method the gravel will only sink into the dirt and disappear and you will have to spent money on gravel every year, my neighbor informed me last week that he is getting 3 gravel train loads this spring because the gravel is sinking into the dirt. Do it right the first time and save money in the long run.
EngineerJoyce
03-25-2004 17:51:37
Most important: USE GEOTEXTILE!!!!!
On top of the bare dirt before the first shovel full of gravel, put geotextile on the driveway and put the rock on top of the geotextile. The trucks driver should be capable of "back dumping" - or dumping the rock as he backs down the driveway, not driving directly on the geotextile.
Geotextile keeps the rock "floating" on top of the dirt. Since rock is heavier than dirt, the natural order of things is for the rock to sink down into the dirt like water, only slower. By putting the geotextile barrier between them, you keep your rock where you want it - on the surface. Using the geotextile will prevent potholes and soft spots and you will NEVER have to add more rock - unless it gets washed off or something.
Geotextile usually comes in 9', 12', and 15' widths. The 9' would be acceptable, but the 12' will give you more "breathing room". 210' x 12' x 4" will make about 60 tons. Add more for a turn-around, about 30x30 for nearly another 20 tons.
Geotextile can be found at most any construction supplier and lots of Agriculture suppliers. An internet search will yield lots and lots of hits. Any rock you put down on top of dirt, put geotextile down between them. Anywhere.
KURT
03-26-2004 01:37:33
 Re: Re: Kinda OT, But how much gravel do I need? in reply to EngineerJoyce, 03-25-2004 17:51:37
I would never use that fabric, it doesnt work, I have proof and it is my neighbors drive. it is all mud
jf
03-26-2004 03:36:08
 Re: Re: Re: Kinda OT, But how much gravel do I nee in reply to KURT , 03-26-2004 01:37:33
don't give out bad advice we put down 1300 feet on sloping driveway and it works great. must have put it down wrong!
john
03-26-2004 05:40:42
 Re: Re: Re: Re: Kinda OT, But how much gravel do I in reply to jf, 03-26-2004 03:36:08
These two post are the reason I have refrained from posting on the subject. Having worked as a operator I have put down thousands of yards of fabric and can say it is not the fabrics fault that it works or not. But recommending the use of or using fabric for any and all soil and rock types is miss leading. It would be like me recommending the use of pilings under a house. Its used under every house in my area so it must be right. Or like someone in Florida and Minnesota trying to say who's house is built right. This is apples and oranges.
Telling some one to use the fabric or not to use it and not explaining the use of it or knowing what type of base it is going on or what types of rocks that are being used is wrong. Please refrain from telling some one to use something that has worked for you without knowing their situation.
john
03-25-2004 20:51:32
I have often seen people recommend the use of geotextile for driveways and have refrained from commenting on the subject because I do not know the type of rocks that are being used in different parts of the country. But I see no warning about using geotextile with some types of rock so thought I would put in my 2 ¢
If you use geotextile with some types of rock you will not be happy. If you are using a rock like crushed limestone that has large and small rock to where it can pack you will be fine. But if you use a one size gravel like is available in our area it will never pack down because the gravel can not pack into the dirt. This will cause your years old drive to be a loose bed like the day it was put down. While I try to put down a good layer of rock when building a drive I do not want one I may get stuck in even years from now. Others may try to put a thinner layer of rock to reduce this but that is not good either as it may expose the geotextile and cause tears in it making it useless.
A remedy to this is to put down your geotextile then add your layer of rock then a small amount of clay dirt. The clay fills the voids allowing the rocks to pack but the geotextile keeps your drive from sinking out of site.
buck
03-25-2004 21:22:53
 Re: Re: Re: Kinda OT, But how much gravel do I nee in reply to john, 03-25-2004 20:51:32
I think it is safe to say that the use of geotex fabrics must be site specfic. Largely dependent on the type of soil/material they cover along with the moisture content of that soil/material. Usage and maintenance methods must also be considered.. The use of geotex fabric over a highly movable material with an erosion pron surface can lead to trouble. Before using this stuff call in a good materials person.
buck
03-25-2004 17:04:03
210' long x 8' wide x.33' deep =554 cu. ft. / 27 = 20.5 cu. yds. x 2 = 41 tons / 16 tons per load = 2.6 loads so 3 loads should do the trick. Loads = typical dandem dump.
