Tractor Talk Discussion Forum
Cat II inplements with a Cat I hitch
Kirk Grau
04-05-2004 14:15:11
Can this be done? I bought a IH 504 a few weeks ago. It has a Cat I hitch. I wanted to hook up a 7' bush hog, but the ones I have seen are Cat II equipment.
The 504 should have enough power for the mower and the 7' just about matches the width of the outside of the rear tires. Besides, I have other things to do than groom pastures.
TIA,
Kirk
Hugh MacKay
04-07-2004 02:49:51
 Re: Cat II inplements with a Cat I hitch in reply to Kirk Grau, 04-05-2004 14:15:11
Kirk: I suspect your 504 came from the factory with either or on Cat I or II. I briefly had a 504 that came with a farm. It had Cat II ends on the hitch. I suspect it was ordered that way as the buyer of it new bought a 504 and 656 in same deal. 656 was standard Cat II. I doubt if it would be very hard to find a set of Cat II ends today. Some tractors you can just turn the ball crossways and it will pop right out and you put the others in.
Kirk Grau
04-07-2004 03:05:03
 Re: Re: Cat II inplements with a Cat I hitch in reply to Hugh MacKay, 04-07-2004 02:49:51
Thanks Hugh,
The manual states that the hitch is Cat I. I have read your 504 story in other places on this forum.
I am pretty sure I can rig something to get this to work, just looking for the most reliable/easiest/cheapest method.
Thanks,
Kirk
Hugh MacKay
04-07-2004 03:39:46
 Re: Re: Re: Cat II inplements with a Cat I hitch in reply to Kirk Grau, 04-07-2004 03:05:03
Kirk: I do remember 504 having Cat II, but I do forget the type of setup. My 656 had the telescoping type end and were quite easy to change the end section of the lower link. Does your 504 have that? I suspect early 504 were solid and later models were telescoping end, but don't remember for sure. You can buy complete weld on ends for these, if you don't have replacable ends.
Dale in IN
04-06-2004 07:52:00
I have a quick hitch that I made that fits cat I that I can pick up cat II impliments.
Kirk Grau
04-06-2004 08:05:26
 Re: Re: Cat II inplements with a Cat I hitch in reply to Dale in IN, 04-06-2004 07:52:00
I like this idea. Can you get a picture or something to give me some ideas for fabrication or purchase.
TIA,
Kirk
Dale in IN
04-06-2004 11:04:16
 Re: Re: Re: Cat II inplements with a Cat I hitch in reply to Kirk Grau, 04-06-2004 08:05:26
I Will Try but it may be a few days before I can come up with one.
hay
04-06-2004 03:27:37
what Ray P. said is right. i also have a catI/catII hitch on my ford 4000. you will need longer hitch pins on the implement as the ball on the lift arms won't accomadate the standard pin.
Jeff IA
04-05-2004 20:45:34
The previous owner of mine removed the factory Cat I ends and welded Cat II ends on the 3pt arms. I think it works great - I can use the bigger bushhog and I just use the Cat I-II adapter bushings on the Cat I implements. I don't know if that's a common practice or not - but I suppose it's an option.
Dug
04-05-2004 14:18:54
Should work as long as your tractor has the horsepower. Just change your Cat II pins to Cat1 on the implement.
RayP(MI)
04-05-2004 17:51:17
 Re: Re: Cat II inplements with a Cat I hitch in reply to Dug, 04-05-2004 14:18:54
Some 3pt hitch assemblies on the tractors have two sized holes in the balls - one cat I, the other cat II. I use a cat II disk on my Farmall 200. Works OK!
