Tractor Talk Discussion Forum
J.D. 1050
Normo
04-12-2004 14:29:36
I have a chance to purchase a 1988 J.D. 1050. It has 1900 hr and the guy tells me there is a knock in the motor. He tells me the knock is becuase of a slipped bearing.
Is this expense to replace? Even if it is worst, what am I looking at for replacing the motor, 3K to 5K?
3K to 5K plus the purchase price still puts this tractor at a great price compared to the others I looked at.
Where woudl I buy a motor for this tractor? J.D. dealer.
Thank you for your help.
Norm
Brokenwrench
04-12-2004 15:15:23
 Re: J.D. 1050 in reply to Normo, 04-12-2004 14:29:36
If that's all it is,you can pull the engine,have the crank turned put in undersize bearings and replace a rod if needed and gaskets and seals for about $850 if you do the work yourself.Check it out closely,I've had some with a bad injector that causes a similar knock. But since you really don't know what you will find,figure on $1500-$2000 in case the crank has to be welded up,block hot tanked and the oil pump replaced,and any other surprises you find.I have 2 in the shop now with spun bearings,750 with 1000 hrs,and a 950 with 1320 hrs.Both are sludged up from a combination of using the cheapest car oil wal-mart sells,(by the owners admission) and overheating.Both radiators are plugged with grass clippings.If you don't want to rebuild,you can find the Yanmar engines on e-bay for $1500 up for used and around $3500-4000 for new ones.
Normo
04-12-2004 18:47:56
 Re: Re: J.D. 1050 in reply to Brokenwrench, 04-12-2004 15:15:23
Wow! Excellent! Even better than I though. I can do this work myself except for I have never worked on a tractor. I have always rebuilt car engines before. Thank you! I think I’ll give it a shot.
