Tractor Talk Discussion Forum
Bobcat 731 hydraulic pump
MGM
04-14-2004 09:56:56
After about 20 to 30 minute when the fluid warms up, the steering goes bad and also if you push against a load the tires do not spin, Does not turn right or left, you can inch it back and forth but the pump somewhere just grumbles, is the problem in the main hydrostic/hydraulic drive pump? Sure could use some input before I rip it down.
Thanks in advance for your help
Mike
Diggerzmound
10-31-2005 09:40:12
 Re: Bobcat 731 hydraulic pump in reply to MGM, 04-14-2004 09:56:56
Make sure before you rebuild to try replacing the inlet filter.
Check link I posted, there are pictures and a thorough description of replacing the filter.
Diggerzmound
10-31-2005 10:03:04
 Re: Bobcat 731 hydraulic pump in reply to Diggerzmound, 10-31-2005 09:40:12
Link
link didn't show up earlier.....
