Tractor Talk Discussion Forum
Submersible Pump Question
trkr
04-14-2004 17:14:40
I know this isnt the right place for this question,but I hope some one can help.My submersible pump control box is making a loud intermittent beep and Im losing water pressure,does this meen its time to pull the pump?Did it about 5 years ago,a miserable job.Thanks in advance.
trkr
04-15-2004 12:39:39
 Re: Submersible Pump Question in reply to trkr, 04-14-2004 17:14:40
Thanks for all the posts.Pulled the pump had a broken wire down by the pump.Works fine now.Like it when you find something obvious,but really glad I didnt need a new pump.
Nor. Al
04-15-2004 04:11:29
Before you pull pump do as one of the other posts advised check the pressure switch, turn off power , open faucet to let off pressure, remove switch and look at the bottom of it where the water goes in it and see if there is a flake of rust , mud or something that is restricting the water from entering it.
TomR Ont.
04-14-2004 18:15:35
I had a simular problem, may symptons were an intermittent snapping, fast re-cycling of the pump (turn on a tap and the tank pressure went low fast the pump would come on, build pressure fast, then repeat about every 7 seconds while the tap was on or flush). My submersible is 220-240v, I took the control box off (just pulls out) and took it to an electrical co they changed the capasitor and something (can't remember the name of it) else that wasn't included in the one at the hardware store. $ 85.00 + $35.00. Then I re-set the Air Pressure and High - Low Limits as per instructions on the tank.
p.s. I was told if I left it snapping it would have damage the pump. Hope this helps.
trkr
04-14-2004 20:10:51
 Re: Re: Submersible Pump Question in reply to TomR Ont., 04-14-2004 18:15:35
Thanks,I called my son,were going to pull the pump tomorrow morning,hope I find something obvious.I have an intermittent beeping almost like its a thermal overload or something,plus now I have no water at all.
TomR Ont.
04-15-2004 00:13:53
 Re: Re: Re: Submersible Pump Question in reply to trkr, 04-14-2004 20:10:51
Check the control box before you pull out the pump .
farmallsc
04-14-2004 17:49:38
well probably, i used to work with a well man. its not try to find somebody with a electric pipe lifter w/ the high boomb
mike a
04-15-2004 12:43:32
 Re: Re: Submersible Pump Question in reply to farmallsc, 04-14-2004 17:49:38
how deep is your well? do you have steel or plastic pipe in it? if its steel,it is a bear,but if plastic just lay a 55 gallon drum on its side at the top of wellhead and secure it to something,possible well casing or stakes in the ground.Pull pipe up and over rounded side of barrel,hook it to a tractor or lawnmower and slowly ride,ride,ride. I've pulled 400 footers this way,never hurts a thing.
trkr
04-16-2004 07:18:34
 Re: Re: Re: Submersible Pump Question in reply to mike a, 04-15-2004 12:43:32
That sounds like real good idea,but mines plastic pipe and only about 100ft. . Me and my son did it by hand but if I ever have to do it alone that sounds like the way to go.
