Tractor Talk Discussion Forum
3400 No Start/Crank
Nick in VA.
04-30-2004 19:50:21
I have a 3400 Diesel-1975 Vintage. Parked it 3 days ago and jumped on it tonight to rake the driveway. No cranking whatsoever. Battery is hot and passes a load test. Cables are clean. I bypassed the neutral safety switch and still no cranking over. No click at starter or relay. No lights either when headlight switch is pulled out, or discharge on needle of amp meter. Anyone aware if this tractor has any kind of fuses or fuseable links? and if so, what area of tractor they would be located on. It's got to be something simple. I am trying to locate a wiring diagram also. Thanks in advance..... Nick in VA.
jake
05-01-2004 03:53:08
 Re: 3400 No Start/Crank in reply to Nick in VA., 04-30-2004 19:50:21
i think you have a problem with the wire coming from the battery to the ammeter.
Nick in VA.
05-02-2004 16:36:37
 Re: Re: 3400 No Start/Crank in reply to jake, 05-01-2004 03:53:08
Jake-you were right on the money. Previous owner had mounted a ampmeter on hood and wire passing through hole had broken off beneath the hood-appearing OK up on top. Was able to access it through the speedo cluster mounting hole. You saved the weekend around here as the wife wanted lots of tractor work done around property this weekend.Thanks again .....Nick in VA.
