Tractor Talk Discussion Forum
Ford Tractor - power steering lines question
AD Trailers
05-31-2004 19:58:33
I have a Ford 2000 tractor, and I am having to spend a lot of time repairing holes in the power steering lines. The metal lines are a silver color, but I cannot tell if they are stainless steel, or what.
I have some spare copper laying around. Can I use copper to replace these lines.
I am referring to the 1/4 lines on the tractor (from the pump to the cylinders).
Thanks for your help!!!
RAB
06-01-2004 00:01:38
 Re: Ford Tractor - power steering lines question in reply to AD Trailers, 05-31-2004 19:58:33
I would not recommend copper for a high pressure hydraulic line. Use the correct material. Often steel originally (tough, cheap, rusts through eventually).Cupro-nickel is common replacement - strong, resists corrosion and easy to work with.
Regards, RAB
Thanks! I got it fixed
06-01-2004 10:37:57
 Re: Re: Ford Tractor - power steering lines questi in reply to RAB, 06-01-2004 00:01:38
Checked with Napa, and they had the exact line pre-assembled for less than $5.
