Tractor Talk Discussion Forum
Model 70d John deere
Ellis Pulling
06-15-2004 13:41:46
I would like to put 18x4x34 on my 70. Would pressed steel wheels be the way to go, or use a differnt size altogether. And would the head on the 70 be able to take the pressure on lp injection.
buickanddeere
06-15-2004 20:07:45
 Re: Model 70d John deere in reply to Ellis Pulling, 06-15-2004 13:41:46
Try the John Deere or the pulling section of this site. I assume you are using putting bigger tires for more traction , pressed steel rims for less weight and LP for extra HP? The G and 70's had such a fast 1st gear that taller tires may over speed you over the limit in " stock classes". If she can make the HP to keep from stalling in heavier than 8000lb classes on clay power tracks. You are likely using a rowcrop chassis rather than a standard chassis? Assuming this is a diesel, the HP restriction is air flow, not fuel flow. The 70's 10mm pumps and injectors can be swapped out for 720/730/ blackdash820/830/840 13mm pumps. Injector tips with 5 or 6 10 thou holes or six 12 thou holes can be used. To improve airflow the 720/730 head can be used as it has larger intake valves and is less prone to cracking. Check the head casting number to see if the upgrade has already been made to your 70. The airfilter can be converted to a dry element, valves backcut and ports blended. LP will just get yourself booted out of the stock class.
Ellis Pulling
06-16-2004 09:51:50
 Re: Re: Model 70d John deere in reply to buickanddeere, 06-15-2004 20:07:45
I was going to take 18x4x34 and shave um down and take air out.either that or 15x5s.I'm pulling in the farm class, so its not intirlly stock, so thats y i asked bout the lp injection. After that i want to put 730 heads on.it is a 70D.
Ellis
buickanddeere
06-16-2004 13:45:04
 Re: Re: Re: Model 70d John deere in reply to Ellis Pulling, 06-16-2004 09:51:50
Stick with the larger tire if possible.
moonlite
06-16-2004 10:00:30
Ellis, Where are you located? Here in Southeast Missouri the Ellis Family is into pulling. They wear shirts saying ELLIS PULLING TRACTORS
Ellis pulling
06-22-2004 18:38:41
 Re: Re: Re: Re: Model 70d John deere in reply to moonlite, 06-16-2004 10:00:30
Im from NE MO, and we don have shirts yet, we havent pulled in along time, we r just now gettin back into it.
Will a powerblock set up be good for my 70D, or just overhaul it and put a 730 head on it. Anyone know wat else i can do to build a fire in it.
Ellis pulling
06-22-2004 18:34:30
