Tractor Talk Discussion Forum
1951 J.D. B BATTERY DRAINS
FRANK
06-21-2004 10:46:41
HELP
IS MY STARTER SHORTING OUT AND DRAINING MY BATTERY WITH KEY OFF,OR IS IT IN THE STARTER CABLE,OR?
RAB
06-21-2004 13:52:26
 Re: 1951 J.D. B BATTERY DRAINS in reply to FRANK, 06-21-2004 10:46:41
Probably not, unless battery and cables heat up seriously. Get yourself a meter and check out with some wires connected and some disconnected until you isolate the offending circuit. Troubleshoot that circuit to find the fault and then rectify.
Regards, RAB
FRANK
06-21-2004 14:16:27
 Re: Re: 1951 J.D. B BATTERY DRAINS in reply to RAB, 06-21-2004 13:52:26
THANKS RAB,
SO ARE YOU SAYING LIKE THE LIGHT SWITCH,KEY SWITCH,THIS IS A POS.GROUND SYS.,IS THIS TRUE EVEN WITH THE KEY IN THE OFF POS.?
THANKS,
FRANK
Ron
06-21-2004 17:06:39
 Re: Re: Re: 1951 J.D. B BATTERY DRAINS in reply to FRANK, 06-21-2004 14:16:27
The diagnostic procedure for battery/generator/electrical problems is exactly the same, negative or positive ground. The only difference is the ground.
The easy way is to charge the battery with a charger until fully charged, check the voltage, and then disconnect the negative battery cable and let it sit overnight. Check the voltage in the morning. If it's the same, the battery is likely OK, if not, you have a parasitic drain which may or may not be a short.
Or, any auto parts store will be happy to load test your battery, usually for free.
