Tractor Talk Discussion Forum
JD 2750
kenthamm
07-09-2004 14:22:04
I have a 84 or so JD 2750 tractor & so far it is a good one, I have one pet peeve when I start it I have to turn the sterring wheel back & forth to get it to turn over fast enough to crank, I have also heard other owners with the same problem. Does anyone know anything about this.
Grant
07-10-2004 11:42:21
 Re: JD 2750 in reply to kenthamm, 07-09-2004 14:22:04
I have a 2755. When it was cold and damp( here on the wet coast cold is 2-5 degrees Celcius) I would sometimes need to crank the wheel.
I replaced the batteries, wires and cleaned all connections and the starter rebuilt. Starts fine now. If it does happen to freeze I plug it in. I probably do not need to as we do not have real winter here.
Overall I think this is a good strong tractor. Not saying I have not had my share of problems with it. We bought it used. It came with a nice bright green new paint job to cover up the previous years of abuse and lack of maintenance.
Grant
Indydirtfarmer
07-10-2004 04:19:55
Are you the Memphis Indiana Kent Hamm? John
Bob
07-09-2004 22:25:35
Deere has had a problem with this on various models. During cranking, the main hydraulic pump begins pressurizing the hydraulic system, which overloads the starter. When you operate the steering sysem, you "bleed off" some of the system pressure, making cranking easier.
Good, fully-charged batteries, clean connections, and a starter in tip-top shape aid starting, even with the added load of the pump.
Deere makes an "electric de-stroking kit" for a number of tractors, which consists of an electric valve, wired to operate while the starter is engaged, that causes the main pump to "go out of stroke", and cease pumping oil during starter operation.
A quick check of jdparts.com failed to show a kit listed for your tractor, but perhaps a knowledgeable Deere hydraulic expert could advise if there is a valve that would work with your tractor.
Mike
07-09-2004 15:54:37
Kent,
I can't speak for the farm but the old JD skidders, 540A model, you had to do the same on them. The hydraulics were shaft driven straight from the motor and "shaking" the steering wheel helped relieve pressure and did make it turn over easier. May be the same type of thing.
mike
