Tractor Talk Discussion Forum
Lye gravy
Dick
07-20-2004 16:11:53
Have Heard about Lye gravy. Would Like to know How to Make It & How To Use It. Thanks In Advance
john r
07-20-2004 22:45:02
 Re: Lye gravy in reply to Dick, 07-20-2004 16:11:53
will it do anything for rust?
Jon C
07-21-2004 04:43:20
 Re: Re: Lye gravy in reply to john r, 07-20-2004 22:45:02
After the part is degreased and the paint stripped, use Phosphoric acid (Ospho), to convert and bind the rust. Works great.
DL
07-20-2004 17:36:29
go to www.fboerger.com click on restoration tips... recipe is there!
regards, DL
Jon C.
07-20-2004 16:28:29
Check out "Frank-in-tallahassee's" web page for an explaination. He does a good job. I have used it to strip paint off my '35 B and it works very well.
Basically its just lye, which can be purchased in a hardware store (Red Devil), mixed in water with some corn starch added to make it pasty so it will stick. You have to play with the proportions to get your favorite consistancy.
Then slop it on with an old paint brush and let the caustic action go to work removing paint. Several coats at half hour intervals or more works great.
Careful as its very caustic and will burn exposed skin...just use some common horse sense when using. You can mix it in a cut open plastic milk jug, as it won't eat through the plastic.
