Tractor Talk Discussion Forum
Using sickle bar for pond weeds?
pijmon
09-08-2004 13:25:44
I'm thinking of using a sickle bar mower (J.D.#39) to mow the weeds around the pond. These are the large stem weeds (cattails)?. I would modify the mower by mounting it on a rolling gear offset in a way that it would keep the tractor high and dry on the bank. A big modication here, so I would like input as to if this would even cut cattails in the first place before I start thid job. Thanks as always for your time... Jim
cockshuttguy
09-11-2004 04:45:38
 Re: Using sickle bar for pond weeds? in reply to pijmon, 09-08-2004 13:25:44
I do it all the time. I use a rear mounted MF dynabalanced unit and it cuts weeds like a charm.
Every now and then you have to stop, lift up while backing to remove a ball of crap at the end of the blade. Watch for muskrat burrows that may cause the tractor to lean more than expected toward the pond water. So far so good.
Good Luck, and be careful
Robert in W. Mi.
09-08-2004 15:51:02
I mow around my ponds with my NH 451 all the time. Cat tails don't stand a chance!!
Robert
paul
09-08-2004 15:31:37
They are a protected species here in my state, so you get in a bit of trouble if you are caught cutting them. Might want to check into that 1st.
The sickle bar mower will cut them.
I'm having difficulty figuring out what it is you are going to modify, if you cantilever the mower many feet to the right, you will have issues with it not cutting while turning as well as the mower pulling the tractor to the side, and the weight will want to tip the tractor, and.... Anyhow, I guess I'm curious how you will make it work? :)
--->Paul
Weirsdale George
09-08-2004 17:29:11
 Re: Using sickle bar for pond weeds? in reply to paul, 09-08-2004 15:31:37
Cattails protected? Are they the state weed or something?
John M
09-08-2004 17:37:42
 Re: Using sickle bar for pond weeds? in reply to Weirsdale George, 09-08-2004 17:29:11
Wetland deal.its illegal t ocut them in some states,but the chances of getting caught are slim.I know when we expanded our building there were some "wetlands",land that stayed wet due to the staes poor system of cutting ditches on new roads,the area stayed wet and cattails grew,the contractor had t oget a permit to bulldoze over them.
red rider
09-08-2004 14:31:13
we have always used a bar mower to mow drainage ditches on our farm. they are filled with a plant lik you are describing
Reido in MO
09-08-2004 14:18:15
I have a 5 foot belly mount on a Supe A, and it cuts everything I can reach.
old operator
09-08-2004 16:26:12
 Re: Using sickle bar for pond weeds? in reply to Reido in MO, 09-08-2004 14:18:15
i have one on a cub loboy 154 cuts as far as it will reach 5 foot
Ronmn
09-08-2004 21:32:53
 Re: Using sickle bar for pond weeds? in reply to old operator, 09-08-2004 16:26:12
The old pulltype mowers were ground driven so you could off set them as much as you want as long as the drive wheel turned it would cut.
