Tractor Talk Discussion Forum
farmall cub wont start
Robyn
10-22-2004 20:57:50
Hello, Can anyone help me I recently purchased a farmall cub 1948 - The problem started like this - sometimes it would fire right up - it has set for a couple of months now. Started up hard today put then ran great - I shut it off to do something and then I it was hard to start again put this time it died like it had ran out of gas - value is on - steady stream from gas line to carb. Appears to be leaking gas from the bottom of the carborator. Unable to get it started at all - ran down 12 volt system attempting to - I had even tried to pull start no luck - I am not a mechanic - but can follow instructions if anyone can give me a hand I would appreciate it.
Thanks Robyn
daniel red
10-23-2004 13:11:08
 Re: farmall cub wont start in reply to Robyn, 10-22-2004 20:57:50
think the float is stuck if gas is poueing out of cARB.
Keith-OR
10-22-2004 22:09:20
should beable to find info on carborator break down,parts list ect...
HTH
Dirty Carborator
10-22-2004 22:04:37
Sounds to me that you have carboator problem, need to clean carborator, make sure needle valve on the input line is seating correctly
old
10-22-2004 21:29:53
Hows the spark? Takes 3 thing for it to run, gas, spark, and compression. Spark should be a blue color if its yellow you probably need new point and condenser and maybe even a new cap and rotor.
