Tractor Talk Discussion Forum
International 350U Hydraulics problem
Briandurga
11-12-2004 10:35:11
Hoping someone may be able to help. I"ve been using the hydrauliucs without any problems until the other day I lifted the 2 point and then went to lower it, nothing happened (no power steering and 2 point)Where do I start to figure whats wrong? I checked the fluid and it was low, refilled and still the same thing. I appreiate any help
Thanks
Brian
briandurga
11-13-2004 15:49:52
 Re: International 350U Hydraulics problem in reply to Briandurga, 11-12-2004 10:35:11
Thanks twopop and bigfred, I got it fixed. I wanted to tell you this funny story of how I did it. I used the messy method by loosening the exit line. I loosened the line until a small air bubble came out and then all there was a steady stream of fluid coming out. after about a minute just fluid and I checked the valve to see if it was fixed, nothing. So I thought that the pump was bad. I kept loosening the line a little at a time until about a minute later. All of a sudden hydraulic fluid came shooting out in every direction, I reached up and turned the tractor off. I must have lost about quart and half all over the stuff in the barn. I must had the line just about off when it happened. Well I tighten the line back up and check the level of fluid and now every thing seems to be okay. I want to thank the both of you for the help, you just saved me a repair shop bill.
twopop
11-12-2004 15:38:29
big freds method is not as messy as mine.on my 350 row crop ,iloosen the small line at the pump and start the engine.when oil comes out,tight the line.
big fred
11-12-2004 11:00:16
You probably lost the prime in the lines to the pump. It happens to my 300U occasionally. What I do is remove the seat cushion, unscrew the reservoir vent then using a rubber tipped air gun I pressurize the reservoir to about 5 psi with the engine running. You can hear when the pump starts working again, as it loads the engine. Replace the vent, replace the seat cushion and you're good to go.
