Tractor Talk Discussion Forum
electric alternator wiring
brio bean
11-12-2004 12:19:15
Does anyone know how to tell which wire is the field wire and which wire is the sensing wire on a 3 wire alternator? The next question is where should each of these wires be connected?
Allan in NE
11-12-2004 12:37:07
 Re: electric alternator wiring in reply to brio bean, 11-12-2004 12:19:15
Bean,
Which alternator?
Allan
brio bean
11-12-2004 14:33:40
 Re: electric alternator wiring in reply to Allan in NE, 11-12-2004 12:37:07
Allan, It's an Hitachi LT135-20 alternator that I'm assuming has its own regulator because the old voltage regulator on the tractor (from prior to its conversion to 12 volt) is totally disconnected. The tractor, an AC WD has been running fine, but we recently had starting problems, and when we undid the wiring harness we discovered that the two small wires from the alternator are not connected anyplace. Any help you can give would be appreciated. Thanks
Jon H
11-12-2004 16:26:30
 Re: electric alternator wiring in reply to brio bean, 11-12-2004 14:33:40
I have no experience with Hitachi alternators,but a fellow who seemed to give reliable advice about alternators once posted this about expermenting with an unknown internal regulator alternator. "Apply 12V to the unknown leads using a test light or small range ammeter,the sense wire will not flow any measurable amperage,while the field/exciter wire will draw several amps". This sounds reasonable,as this is how it works on the 10-12 SI Delco alternator. The sense wire should be connected to the alternator output stud and the exciter wire should be connected to battery power only when the ignition switch is on. The Hitachi may or may not need a Diode or resistor to block return flow if the exciter wire is connected to the ignition terminal of the ignition switch as is necessary on a Delco internal regulator alternator.
Are there loose dangling wires from the alternator or are there just terminals with nothing connected? Maybe you should check if the alternator charges without these other wires connected on the chance it has some sort of one wire conversion like is done with the Delco alternators.
Frank Kovarick
11-13-2004 23:15:59
 Re: electric alternator wiring in reply to Jon H, 11-12-2004 16:26:30
If it's like the Delco with internal regulator, there's only one wire to the ammeter to show charge etc. There is another connector that requires a small amp surge to get the field excited on start up. I just use a push button switch but have to remember to push this button to start the charging when the engine starts after a shut down. I tried to wire a small dash lamp into this circuit off the ignition switch to provide the necessary small amp jolt to excite the field but haven't gotten it to work so I revert to the push button switch. When I got the tractor, an 8N with the 12V conversion and the Delco alternator, the guy just had a short wire with the end insulation off and hot wired and he just brushed that other connection with this wire to energize the field. Not much finese.
