Tractor Talk Discussion Forum
1963 Int'l Harvester 300 Utility
Glenn Wood
12-16-2004 16:44:14
New to tractors. Just drained 80/90 gear oil and having trouble locating the fill hole for new oil. Can anyone help?
TDK
12-16-2004 18:45:22
 Re: 1963 Int'l Harvester 300 Utility in reply to Glenn Wood, 12-16-2004 16:44:14
The 300 Utility was only built in '55 & '56, so it can't be a '63. If yours is a 300U, then the 1 1/4 fill plug is located on top of trans. beside shifter. The level plug is on left side of trans. about half way down the side.If your tractor has T/A then IH Hy-Tran ONLY should be used in it. Hope this helps!
