Tractor Talk Discussion Forum
3010 gas runnig rich
Case14123
01-13-2005 11:28:32
I have a 1963 3010 gas tractor that runs very rich on fuel and would like to know if anyone has a soloution to this problem ,I have rebuilt the Mavel Shebler carb and it has not improved the tractor performance at all it still runs rich . Will a Zenith carb help? Any ideas are welcome.
Mike M
01-14-2005 06:47:30
 Re: 3010 gas runnig rich in reply to Case14123, 01-13-2005 11:28:32
If you have that aluminum carb. get rid of it and get a cast iron zenith unit. This is the single best improvement you can make.
J. Schwiebert
01-13-2005 12:01:53
When you rebuilt the Marvel Shebler did you check the power jet with a vacuum gauge? Did you change the diapram?
case14123
01-13-2005 13:28:08
 Re: 3010 gas runnig rich in reply to J. Schwiebert, 01-13-2005 12:01:53
I had the carb rebuilt by a JD tech but I doubt he checked vacum or replaced diapram unless it was in overhaul kit . Could give me more details on this process?
Hoosier JD
01-13-2005 14:38:54
 Re: 3010 gas runnig rich in reply to case14123, 01-13-2005 13:28:08
I rebult the Marvel on my 4010 with not much improvement. I talked to JD and they said that when the 10 series came out, they were instructed to replace the Marvel with Zenith if anyone had problems. So I bit the bullet and bought a Zenith from Restoration Supply. This was probably the best improvement that I have done to my tractor. I don't work it except for plowing snow and playing, but it seems to go twice as long on the same amount of fuel. It also was a lot easier to adjust. Good luck. Mike
