Tractor Talk Discussion Forum
ford 2n
dave guest
01-21-2005 20:03:28
Changing over to 12 volt. What resistor size would be ideal if I keep the 6 volt coil. I am trying 3.5 ohms but would like to know for sure. Thanks a lot!
Bob
01-22-2005 01:09:19
 Re: ford 2n in reply to dave guest, 01-21-2005 20:03:28
Retaining the original ballast resistor and adding another 1.6 Ohm resistor IN SERIES works well.
The original resistor is a positive temperature coefficent resistor, meaning that it starts out at a low resistance when the ignition is first energized, and then the resistance increases over a period of a minute or two.
This provides a "hotter" spark for starting, when the starter is drawing down the battery voltage, and then the increase in the resistance helps with longer point life and a cooler-running ignition coil.
Retaining the original ballast resistor and adding the additional resistance keeps the PTC feature, for easier starting.
RAB
01-22-2005 00:27:05
Measure volts across coil and across resistor. You will soon see if coil is getting it"s fair share (ie. near it"s rated voltage) of power.
Regards, RAB
