Tractor Talk Discussion Forum
Ummm, what's a rock shaft...
Tanklord
01-22-2005 19:12:06
and why is a drainage pipe called a "tile" up North? This Cajun would like to know!
Tanklord
01-23-2005 10:36:04
 Re: Ummm, what's a rock shaft... in reply to Tanklord, 01-22-2005 19:12:06
Thanks guys. I always learn something new everyday on YT. Have a good day!
Willy-N
01-23-2005 08:52:43
Called a Rock Shaft because it is a Shaft the Lift Arms Rock on. Mark H.
oliver green
01-23-2005 06:22:49
My Dad worked at clay tile factory off & on for 35 years. i spent early work years allso. Made lots of sewer pipe,drain tile& chiminy flus. Tons of it still in ground today.
Steve/TN
01-22-2005 20:10:17
Early drain pipes were made out of tile pipe, like our old sewer lines. Many still are. The rock shaft is the large shaft that is the guts for 3 point hitches.(The shaft that rotates and causes the 3 point hitch to rise or fall.) That's what I always called it. I could be and probably am wrong.
RAB
01-23-2005 02:01:40
 Re: Ummm, what's a rock shaft... in reply to Steve/TN, 01-22-2005 20:10:17
I hope your sewer pipes were not porous!!
Regards, RAB
steve from mo - dangit!
01-23-2005 20:03:42
 That's just the point. in reply to RAB, 01-23-2005 02:01:40
Outside the city, sewage is treated by digestion in the ground. A porous clay tile drain field worked pretty well for that.
Rockin' Farmer
01-22-2005 22:31:06
You're right on, Steve!
Rockin' Farmer
