Tractor Talk Discussion Forum
Can the 3-pt lift the rear of a tractor ?
jCarroll
01-28-2005 19:02:22
Do I recall correctly a device which attaches to the tractor and the 3 pt which will lift the rear end of the tractor - or did I eat some bad pizza?
Any pictures/links?
thanks
TimV
01-29-2005 07:36:11
 Re: Can the 3-pt lift the rear of a tractor ? in reply to jCarroll, 01-28-2005 19:02:22
Our IH 300 utility would lift the rear wheels of the tractor. Note that this is not "really" a 3-point--it"s an IH "fast-hitch" 2-point setup. Sure did make putting tire chains on easier!
john in la
01-28-2005 20:16:43
third party image
Like this
jwm
01-28-2005 19:13:53
You recall correctly. It is a tractor jack made by Ford. They can be found on e-bay from time to time. It lifts all four wheels at once. James
Keith-OR
01-28-2005 20:30:09
 Re: Can the 3-pt lift the rear of a tractor ? in reply to jwm, 01-28-2005 19:13:53
Case made one that raised just the back end of tractor Using the lift arms of the Eagle Hitch.There is a picture in the owners manual for Case 300 series tractors. If I can get my scanner to work correctly will post on this forum or can email it to you. I took some digital pictures of it, but did not come out very clear.
Keith in Gods country
Nebraska Cowman
01-29-2005 10:26:44
 Re: Can the 3-pt lift the rear of a tractor ? in reply to Keith-OR, 01-28-2005 20:30:09
Oh shoot keith, lights are coming on now. I have some kind of stand that is marked D-C S-C and have wondered for years what it is. I'll get a pic and email it to you.
Old Pokey
01-28-2005 22:11:50
What part of "Gods country" are you in Keith? I'm in Hillsboro, just west of Portland.
Keith-OR
01-29-2005 09:22:37
 Re: Can the 3-pt lift the rear of a tractor ? in reply to Old Pokey, 01-28-2005 22:11:50
Pokey, I am 200 miles east of you. couple mile south of the Columbia River.
Old Pokey
01-29-2005 12:50:45
 Re: Can the 3-pt lift the rear of a tractor ? in reply to Keith-OR, 01-29-2005 09:22:37
That should be somewhere around Pendleton I think, right? Nice country. My dad had a ranch in Antelope years back. I sure do miss that country. It's so nice and quiet.
Van in AR
01-28-2005 20:10:00
Or if you got a IH with a fast hitch, you can lift it with a block of wood.
Van
Hugh MacKay
01-29-2005 03:06:20
 Re: Can the 3-pt lift the rear of a tractor ? in reply to Van in AR, 01-28-2005 20:10:00
Van: Just looked at that Ford device, don't think I'd want to tackle a very big tractor that way.
On the IH, SC, 200 and 230 will do it quite easily. My Farmall 300 with full chloride and one set of wheel weights would not lift rear wheels. My uncles 300 utility with chloride would. My Farmall 560 with no weight added would not raise rear wheels. They would each raise one wheel at a time. That seemed to be the story with larger IH, some would, some wouldn't. I think it was a case of how much weight added.
Van in AR
01-29-2005 08:04:58
 Re: Can the 3-pt lift the rear of a tractor ? in reply to Hugh MacKay, 01-29-2005 03:06:20
Hugh,
Both of my 300 Farmalls will lift one side and one will lift both, pump is a little weak on the one. And no I would not want to lift anything of any size with that ford rig.
Van
edchainsaw
01-29-2005 20:43:18
 Re: Can the 3-pt lift the rear of a tractor ? in reply to Van in AR, 01-29-2005 08:04:58
JD had one of these too.. but for 30's Dabuque tractors only..... not the bigger tractors
