Tractor Talk Discussion Forum
Buzz saw can it be turned in to a small saw mill
old
01-31-2005 19:21:00
I have been thinking about doing this for years and wondered if any body else has tried to do this??. I have one with a 24 inch blade and I have lots of trees and would love to fiuge out how to use it to make say 10inch squire beems and or 2X10 etc. any ideas and or pictures???
THANKS
Buzzman72
02-02-2005 05:31:38
 Re: Buzz saw can it be turned in to a small saw mi in reply to old, 01-31-2005 19:21:00
Buzz saw THIS! Buzz saw THAT! Frankly, it's gettin' old pretty quick.
I DIDN'T SEE NOTHIN', and YOU COULDN'T PROVE IT IF I DID!
Les...fortunate
02-01-2005 07:41:54
Rip saws' teeth are swaged. Crosscut saws' teeth are set. It would be easier to take a rip saw (like on a sawmill) and turn it into a crosscut (buzz saw) than it would to go the other way.
You can file alternate corners off swaged teeth to give them "set" but it would be quite the project to take teeth that have been set and swage them. I wouldn't want to do it.
Rod in Smiths Falls, ON,
02-01-2005 05:04:11
I buy some lumber from a farmer who has a small mill run off a tractor's pto.
It doesn't cut very accurately, but it is fast and cheap, compared to a band mill.
Roger in Kansas
01-31-2005 20:36:03
I will have to agree with Nebraska Cowman. We started with a 48 inch blade, went to a 52 inch blade. Still can't cut a very big log. You need room over the spindle or arbor shaft for the carriage to run.
thurlow
01-31-2005 20:28:22
Different hook angle on the teeth; cross-cut versus rip..... ..
Nebraska Cowman
01-31-2005 20:12:08
no, a 24 inch blade ain't near big enough to cut 10 inch timbers. To get a ten inch timber you are looking at a log maybe 20 inches on the big end. I'd say a 36 inch blade would be a bare minimum and 40 or better would be best. I'd try buying one of those bandsaw mills. I bet you get back in Amish country you could pick up a good one for less than $2500.
old
01-31-2005 22:42:54
 Re: Buzz saw can it be turned in to a small saw mi in reply to Nebraska Cowman, 01-31-2005 20:12:08
Shot if I found one for $500 it would be more then I could spend at this time. Oh well I guess I'll go back to my chain saw mill again it works just slow
Gus
02-01-2005 02:54:44
 Re: Buzz saw can it be turned in to a small saw mi in reply to old, 01-31-2005 22:42:54
Old, does your saw use a different chain for ripping? Or does the normal chainsaw chain work?
Gus
old
02-01-2005 09:12:37
 Re: Buzz saw can it be turned in to a small saw mi in reply to Gus, 02-01-2005 02:54:44
A normal one works but it is better if you have a ripping chain. The set up I have is call an Alsaka mill sorry about not spelling it right.
