Tractor Talk Discussion Forum
sorta OT: mm 403 power unit
mattd
03-01-2005 18:16:39
i just bought a minneapolis moline 403 power unit at an auction. what is interesting about this motor is instead of a mag, it has a distributor of of a v-8 engine. this is a 4 cylinder engine. what the previous owner did was run a spark plug wire on every other nipple. then he melted the tops of the other 4 to keep water out. i think this is a good idea if the motor actually runs. what i am confused about is that there is a throttle cable that runs to the distributor. does anyone have an idea what this would do. i think it might be some sort of timing thing. before i realised that it went there i messed with it. it wont be a while till i run it, but i would like to find out what this cable does. thanks for any help
matt
Gene Davis (Ga.)
03-01-2005 18:28:39
 Re: sorta OT: mm 403 power unit in reply to mattd, 03-01-2005 18:16:39
The distributor from a V-8 engine would have a vacum advance on it to advance and retard the spark timing. The cable is probably hooked to the place where the spark advance unit had been hooked to the breaker point mounting plate on the inside of the distributor. However this is really only my sight unseen guess. Gene Davis
