Tractor Talk Discussion Forum
Pipe thread tape with gas/oil
bigblue
03-04-2005 17:43:14
Can you use regular plumbers pipe thread tape on threads exposed to gas or oil?
bigblue
03-05-2005 05:44:00
 Re: Pipe thread tape with gas/oil in reply to bigblue, 03-04-2005 17:43:14
Thank you all for your advice.
Mike from cny
03-04-2005 22:32:02
I've had good luck with leak lock. It seems to cut right through oil. I rebuild refrigeration compressors (carrier) and its good enough to seal in refrigerant.
Joe Evans
03-04-2005 21:53:28
Personally, I hate teflon tape especially in applications where there is a possibility of teflon tape bits plugging a port or jet.
Rectorseal 5 or Gasoila Soft Set is my ticket with Gasoila being the better of the two. Gasoila's name pretty much tells you it's OK for the your application.
T_Bone
03-04-2005 20:19:03
Hi BB,
Yes teflon tape is a UBC (Uniform Building Code) approved pipe thread sealant for gas or oil.
Tape or soft sealant must start one thread from the end of pipe (this stops sealant from entering into the pipe) and tape sealant must wrap a minimum of three times around the threads (I like 5 wraps).
That is if the sealant mfg meets the UBC code requirements. Some cheap brands of sealants do not apply for code ratings thus can not be used.
Sorry my brain won't kick out the plumbing code marking, ie; like UL.
T_Bone
thejdman01
03-04-2005 20:04:31
alberta is correct yellowish (light yellow) works w/petrolium products and many many other things i usually just stock the yellow works where the white does and more.
37 chiuef
03-04-2005 19:38:06
I think the only place where teflon tape works good is on plastic. For metal I use the past sealer. Stan
Gerald J.
03-04-2005 19:23:15
The only trouble with teflon tape is that bits tear loose while tightening and sometimes get to plug things like carburetor jets and needle valves.
I've used white teflon for gasoline successfully.
The better seal is Rectorseal. It holds oil up to hydraulic system pressures and holds LP gas and liquid as well as water.
Gerald J.
AZ Jack
03-04-2005 19:10:09
Ace Hardware has it in tubes along with regular pipe dope. It specifically lists it as being able to use with gas etc.
Alberta Mike
03-04-2005 18:19:28
Somehow I think that the "white" teflon tape isn't as good on petroleum applications (gas, oil, etc) as the "yellow" teflon tape. I might stand to be corrected on that.
Jeff In Ontario
03-04-2005 17:45:20
Blue:
I think you can--- however--- I bought some that specifically stated that it could be used on gas applications.. i think i'd use that to be safe. (By the way it worked great!)
Jeff
