Tractor Talk Discussion Forum
MF690 leak's motoroil in front
Bjarne
04-10-2005 23:17:25
I have a MF690 '83, 8000 hours. It leak's motoroil from the bottom bearing, in front
of the motor block. Any help please.
Best regards Bjarne ( Denmark ).
Bjarne
04-10-2005 23:18:58
 Re: MF690 leak's motoroil in front in reply to Bjarne, 04-10-2005 23:17:25
It leak's behind the lower belt pulley, in front of the motorblock.
Farmered
04-11-2005 01:35:18
 Re: MF690 leak's motoroil in front in reply to Bjarne, 04-10-2005 23:18:58
I assume that you mean leaks and not leak's. The ' indicates that something belongs to the leak. The engine's front pulley will have to be removed. ' Indicates that the pulley belongs to the engine. You will need a puller. It may be easier to remove the front cover to change the seal. In that case you will also need a front cover gasket.
