Tractor Talk Discussion Forum
tire presures
dan67
04-14-2005 20:21:20
great advise as always from this site.. Just had new rubber installed on my "H" 13.6x38. What is a good working pressure for field work. thanks
buickanddeere
04-15-2005 11:27:34
 Re: tire presures in reply to dan67, 04-14-2005 20:21:20
Lower pressure is less soil compaction and higher yeilds. As long as the sidewall isn't rippling or bulging as previously stated. You are not putting enough HP to the ground to worry about slipping the tire bead on the rim.
txgrn
04-15-2005 07:42:22
I like my rears soft so I keep pressure as low as I can without too much sidewall flexing....10 to 13 on most of my tractors; even the 100 hp.
Mark
Allan in NE
04-15-2005 10:01:26
 Re: tire presures in reply to txgrn, 04-15-2005 07:42:22
You bet Mark,
That's the pressure where they'll "grab".
Allan
txgrn
04-15-2005 17:11:45
 Re: tire presures in reply to Allan in NE, 04-15-2005 10:01:26
Whatever you say boss man. You're the man.
Get em.
Mark
RustyFarmall
04-15-2005 06:59:50
This is straight from the manual. Minimum pressure- 12lbs. When plowing, increase pressure in furrow tire by 4lbs. Maximum pressure 16lbs.
old
04-14-2005 20:36:44
around 15-20psi depending on what your doing less for more traction more if not needed
