Tractor Talk Discussion Forum
Crankshaft belt replacement
48Marty
06-01-2005 10:25:57
I have a 1940s era Farmall H. The cranshaft to waterpump belt broke and I can"t see how to replace it. Any ideas? Thanks
Kevin Bismark
06-01-2005 17:17:31
 Re: Crankshaft belt replacement in reply to 48Marty, 06-01-2005 10:25:57
I am pretty sure it"s the same as the M, look for a set screw on the pulley on the waterpump, loosen it up and then screw the front part of the pulley to get her loose, you can slip the new belt between the radiator and the fan blades but it"s going to be kind of tight but it should go..
48Marty
06-02-2005 09:54:02
 Re: Crankshaft belt replacement in reply to Kevin Bismark, 06-01-2005 17:17:31
Thanks Kevin, I"ll give that a try. It does look like it will unscrew.
