Tractor Talk Discussion Forum
loader for jd 2030
cb
08-04-2005 05:45:14
we have a jd. model 2030, we want to put a loader on it. we are seeing several models advertised around. we talked to several of them and can't get a similar answer on which will fit. what series/models were made for this tractor. don't want to do much modifying. thanks
j cook (iowa)
08-05-2005 07:21:00
 Re: loader for jd 2030 in reply to cb, 08-04-2005 05:45:14
I have a 2440 (same size as a 2030 but newer) and it has a JD 145 loader. The 145 loader is the model designed for the 2030, according to the OM for the loader. It works very well. Mine has it's own set of valve spools, which allows the continued, independant use of the rear remotes.
cb
08-05-2005 15:19:07
 Re: loader for jd 2030 in reply to j cook (iowa), 08-05-2005 07:21:00
thanks for the info, i ran across someone with a 145, he said it would work, but i have talked to others and they said other models would fit.[ not a 145.it was their loader] mr. j. cook, do you have any relatives/ancestors in MS. have a nice day.
txgrn
08-04-2005 18:28:52
www.koyker.com
cb
08-05-2005 05:45:11
 Re: loader for jd 2030 in reply to txgrn, 08-04-2005 18:28:52
thanks for the reply. i checked out the web site of koyker, did not list anything that would fit a jd 2030. as i said i talked to several people about loaders, most said what they had would fit. i need to know the models. i checked with the jd dealer they want SN #'s before they can tell me anything.
