Tractor Talk Discussion Forum
Tire fluid
Steve in Mo
08-25-2005 13:27:57
Need to replace both rear tires on my Farmall Cub. One tire, tube, mounted and filled with windshield washer fluid $170 seems high to me but can't find anything cheeper of equal value. The real question is what do you all think of washer fluid instead of cal. clo.
dhermesc
08-26-2005 06:32:48
 Re: Tire fluid in reply to Steve in Mo, 08-25-2005 13:27:57
8.3 x 24 $85 plus shipping
Link
Leland
08-26-2005 04:08:19
I would rather just hang iron and forget about fluid this way I can take weight off when not needed and tires last longer on road.
msb
08-25-2005 17:26:13
So they tell me ,beet juice is the latest for fluid in rear tires.
supergrumpy
08-26-2005 07:56:51
 Re: Tire fluid in reply to msb, 08-25-2005 17:26:13
I have some beets, how do I get them thru the valve stem??
old
08-25-2005 13:59:12
I've had good luck with WW fluid. If I remember right your a little north of me but it should still work ok up there. I have one tire filled with cacl and one with wiper fluid and don't see much differance in the 2. But I also fill my own tires not very had to do. All you need it the page from an owner manual I have to do it easy. If you would like a copy drop me an e-mail.
Illinois Boy
08-25-2005 13:39:17
If it was me - I'd leave 'em alone. I've had enough rim headaches from calcium chloride. But other than my own humble opinion, I can't hep you with the windshield washer vs cal clo question; except that I know that washer fluid will freeze if it gets, and stays very cold.
tyre_guy
08-25-2005 17:46:04
 Re: Tire fluid in reply to Illinois Boy, 08-25-2005 13:39:17
I would recomend that you look for someone local who sells Rim Guard tire ballast. It is a base instead of an acid so it cannot cause rust and also it is much heavier per gallon than window washer fluid. Here is the web address. Link I am in Iowa so depending on what part of Mo you are at I would be glad to ballast your tractor.
