Tractor Talk Discussion Forum
Bio Deisel
BOB E
08-29-2005 03:33:07
Can I use bio diesel in my oil furnace
T_Bone
08-29-2005 05:57:23
 Re: Bio Deisel in reply to BOB E, 08-29-2005 03:33:07
Hi Bob,
Yes you can although B100 has less engery per gallon than #2 B100=127,000btu/gal #2=131,000btu/gal
T_Bone
Jay (ND)
08-29-2005 10:18:49
 Re: Bio Deisel in reply to T_Bone, 08-29-2005 05:57:23
#2 has 140,000 BTUs and 100% Bio is about 130,000 btu.
T_Bone
08-30-2005 01:09:16
 Re: Bio Deisel in reply to Jay (ND), 08-29-2005 10:18:49
Hi Jay,
That would about right for ruff gross heating values but what we actually see and use is net heating values that has lower BTU's mostly from water content and the crude oil soruce.
The location of the source has a huge roll in determining net BTU's per gallon wheather it be dino oil or vegetable oil.
Example: From my combustion engineers handbook for gross BTU/lb
#2 Alaska crude= 18470btu/lb
#2 MiddleEast crude= 19070btu/lb
#2 Venezuela crude= 18400btu/lb
Clean #2D contains about 500ppm of water contained with-in the fuel.
Clean B100 contains about 1500ppm of water contained with-in the fuel.
Both quotes from ASTM standards.
T_Bone
Jay (ND)
08-30-2005 02:52:00
 Re: Bio Deisel in reply to T_Bone, 08-30-2005 01:09:16
Ok, true, but BTUs are not measured in net benefit. The given standard is 140,000 for #2 and 130,000 for bio. I mean, you don't say a candy bar only has 200 calories instead of 300 just because 100 calories go out the waste chute. Sure, some #2 and Bio will vary in BTUs, but only by 1000 or 2, not 10,000.
And while ASTM does say that 500 ppm of water in #2 and 1500 ppm in Bio is acceptable, that does not mean that there is any. Do not confuse acceptable standards with actual results.
T_Bone
08-30-2005 04:57:27
 Re: Bio Deisel in reply to Jay (ND), 08-30-2005 02:52:00
Hi Jay,
Indeed if your designing combustion equipment you very well use net BTU values or you will underdesign the equipment.
Using your example, you would need to eat 1-1/2 candy bars if the total requirement was 300 calories needed as the net calories of the candy bar was only 200 net calories per candy bar for whatever reason. 1.5x200=300
As soon as any oil gets exposed to the atmosphere it starts gathering moisture content.
T_Bone
