Tractor Talk Discussion Forum
Starter flywheel housing borken
steve_ne
09-19-2005 08:59:39
Has anyone ever had the housing that comes up around the flywheel on a starter break in two. Had one break friday makes a very very bad sound I shut it down fast. What would make this happen? Vibration?
Is it time to call "New Orleans" just "Orleans"?After Katrina there's not much new about it.
Steve_ne
09-19-2005 19:18:01
 Re: Starter flywheel housing borken in reply to steve_ne, 09-19-2005 08:59:39
Just got my starter back with a new housing. Started great more than 30 times. Then made a squeal. I removed the starter and the housing is broken again.
Bob
09-19-2005 21:47:12
 Re: Starter flywheel housing borken in reply to Steve_ne, 09-19-2005 19:18:01
Inspect ALL the teeth on the flywheel's ring gear. Very likely, a tooth or two are damaged, or folded over, or there is s piece of debris between a couple of teeth.
old
09-19-2005 10:09:50
Yep seen that before. Most of the time its caused by the starter not disengageing the flywheel and then the starter freezes up and bang broken parts. Not a good thing either.
