Tractor Talk Discussion Forum
Fuel sender floats
ATM
03-05-2006 13:58:23
Hey guys
I have two fuel sender floats that are leaking and are full of fuel.
I drilled a small hole and drained them and was wondering if you can buy just the float?
Or is there something you could fill them with that floats and is impervious to gas and diesel fuel?
I know you can buy new senders for about $25 but the old ones still work.
Thanks Al
Bob N.Y.
03-05-2006 15:38:04
 Re: Fuel sender floats in reply to ATM, 03-05-2006 13:58:23
I have never tried it, but I have thought about using a plastic pill bottle that seals tightly as a float.
Mike M
03-05-2006 14:29:35
I am able to get floats at my local radiator shop,they also deal in gas tanks.
Bob
03-05-2006 14:26:13
The floats are brass, right?
Shine up the brass around the holes you drilled.
Use a good-sized soldering gun. Allow the tip to pre-heat, and have a drop of molten solder on the tip, and quickly touch it to the float, and get the hole covered with solder, before the whole float and the air inside it heat up, and the air begins to bubble out through the dab of solder over the drilled hole.
Then, hold the float immersed in warm water, and you will see air bubbling out through the original leak. Once the source of the leak is identified, you can melt the dab of solder off of your drilled hole, to make an air vent, and then solder the original leak. You may have to unsolder the halves of the float, and take it apart to clean the seam area, if the leak is at the seam where the halves join.
When you get the leak soldered up, allow it to cool to room temperature, then quickly solder the vent hole shut as was done previously.
Don't overdo it with the (heavy) solder, or you will have a "sink", rather than a "float"!
If you can't repair the float, I have some new ones on hand. Unfortunately, they cost about $15.00, and, if you can really get a whole new sender for $25.00, that sounds like a good deal!
bigcoulee@hotmail.com
tools
03-05-2006 14:14:07
Well, you can get one for $5 for a old Chevy pickup. I've also used 35mm film canisters in the past with luck.
Tools
Bob
03-05-2006 14:27:35
 Re: Fuel sender floats in reply to tools, 03-05-2006 14:14:07
tools,
Can you list a source, and part # for the $5.00 floats?
I've been paying WAY more than that!
