Tractor Talk Discussion Forum
Hot Kubota
gas
04-12-2006 20:59:09
Have a Kubota M4050DT. When in use Temp Gauge goes to Hot. Does not seem hot, does not boil out coolant and temp at upper radiator hose 205 deg. checked with thermo-sensor. What could be problem?
JMS/MN
04-13-2006 08:31:01
 Re: Hot Kubota in reply to gas, 04-12-2006 20:59:09
Gauge or sender could be bad. To check sender, disconnect wire at sender, with key on, ground that wire to the frame of the tractor. Gauge should read to the max- means gauge is good and sender is bad.
jhill
04-13-2006 04:31:27
Probably a bad temperature gage sending unit.
