Tractor Talk Discussion Forum
Ferguson Block
Joey Lasselle
04-25-2006 08:39:53
My uncle bought a 1951 Ferguson TO-30 tractor, and was told the headgasket was blown, but it turns out the block is cracked inbetween the pictons and all the way through on the bottom side of the piston liners, and through the main Web inside the engine. its toast.. If anyone knows where or to get a Z129 ferguson block, or knows someone who can get one, or an whole rebuildable engine let me know!! thanks
Jerry/MT
04-25-2006 09:01:46
 Re: Ferguson Block in reply to Joey Lasselle, 04-25-2006 08:39:53
There is a furnace brazing process that can be used to repair the Continenetal block so you can probably find one through a local machine shop. This was a common occurance for overheated Continental blocks and the old fixit proceedure used tension rods through the water jacket to hold it together. The new method is a much better way of fixing this problem and you can probably have your block repaired by furnace brazing or get a repaired block in exchange. It depends how fast you want to get your tractor back n operation. I think the cost is around $400-500 for a repaired block exchange and that includes align boring and remachining the block to the proper dimensions.(The casting gets stress relieved in the process so it has to be re machined.) I have a remanufactured block like this and the engine runs like a top.
