Tractor Talk Discussion Forum
towing an airstream
Marvin Gill
05-02-2006 21:26:43
Hello. I was wondering if it would be safe to tow a 26 ft. long Airstream trailer up a 30-35 degree dirt driveway about 500 feet long with a 1953 Farmall Super M widefront tractor that is in good condition? Also, I noticed that a lot of people put a ball on the front of their tractor or cat and pull with the front. Is this safer or easier than pulling with the rear? Thanks for your input--Marvin
Marvin Gill
05-09-2006 13:50:21
 Re: towing an airstream in reply to Marvin Gill, 05-02-2006 21:26:43
This is what I think I will do: I will find a railroad tie that is as long as the trailer is wide. Then I will suspend it from each end of the rear bumper on the Airstream. I will make the chains long enough so if the trailer rolls back, hopefully it will roll into the tie. Or I could just get one person on each side of the trailer and pull the tie up behind the trailer. Any takers?
Ga Jack
05-03-2006 18:05:59
SECOND THOUGHT, CHECK INTO A MOBILE HOME MOVER.
THESE GUYS HAVE HITCH BALL HOOKUPS ON THEIR BIG RIGS FOR PULLING THEIR STUFF. COULD BE SAFER AND MAYBE CHEAPER.
jackie
Ga Jack
05-03-2006 17:59:29
M. GILL,
DOES NOT THIS TRAILER HAVE SOME TYPE OF BRAKES?
ELECTRICAL, WORK OFF YOUR TRACTORS SYSTEM OR FIT IT WITH A SWITCHING SYSTEM OFF A HOT BATTERY.
HYDRUALIC,SURGE PROTECTED MAYBE? PLUM INTO THIS SYSTEM AND WORK FROM THE TRACTOR. MY NUMBER ONE QUESTION, ARE YOU GOING TO ATTEMP THIS MOVE ALONE WITH NO EXTRA HELP? MIGHT BE BEST,IMO, TO HAVE A FEW EXTRA HANDS AND EYES WITH A WELL THOUGHT OUT PLAN IF YOU THINK THIS MIGHT BE A BIT "HAIRY". BE SAFE,GOOD LUCK, jackie
Marvin Gill
05-03-2006 17:49:30
third party image
Here is a pic of the road. I think you guys have talked me out of trying this. Maybe for the better.
in-too-deep
05-03-2006 17:05:23
I'd put as much weight as you have available on that tractor. Maybe you could devise some kind of quick-detach hitch so if you don't make it up the hill you could cut the trailer loose and save yourself and the tractor? Just an idea. Oh, one more thing....1ST GEAR!!! ; ) Good luck!
sammy the RED
05-03-2006 05:08:06
A Super M will out pull your bro's 1/2 ton Chebby.
Hook it to the rear, not the front.
VaTom
05-03-2006 04:48:38
Marvin, you sure about that "30-35º"? I replaced my 30% (16.7º) driveway "cause it was 4x4 everytime it rained. 30-35º is well over 50%.
No way would I consider pulling something that heavy up such a steep slope knowing that all it took was losing traction to start going backwards, uncontrolled.
If you do have that much slope, you need a winch with it anchored firmly at the top. Or, an all wheel drive tow vehicle that weighs a lot more than that trailer. If you"re near here, I have both. Have to see that slope, but I"m pretty sure I"d only winch it. And I"ve only got 200" of cable on my winch. Could be an interesting exercise.
Be careful.
jd9295
05-03-2006 01:17:16
if the brakes are good on the M you wont have any problem.
The ball on the front is to make it easier to back a trailer in somewhere, i wouldnt do it pulling that trailer up hill, the weight will be needed on the back of the tractor
Mark - IN.
05-02-2006 22:02:52
An M isn't a very big tractor, but she sure has the muscle to come up when push comes to shove. I wouldn't try it myself, but others may have different thoughts. You do NOT have my blessing on that one, sorry.
Out of curiosity, what do you pull it down the road with, and why aren't you using that?
Mark
Marvin Gill
05-02-2006 22:19:59
 Re: towing an airstream in reply to Mark - IN., 05-02-2006 22:02:52
Hi Mike. Well, I need to move it up to my new house which is a ways from where she is parked. I have never towed the trailer and plan on using it as a storage unit. My brother originally pulled it to where it sits now with his 78' Chev heavy half-ton. I do have a 96' Dakota 4x4 but it seems to me like the tractor would pull it better? Don't know what my reasoning there would be. Thanks anyways!
Mark - IN.
05-03-2006 16:29:48
 Re: towing an airstream in reply to Marvin Gill, 05-02-2006 22:19:59
Yep, I'm thinking that the Dakota would get hurt badly, especially if has an automatic trans.
Is no doubt that the M has enough cahunas for that airstream and more, and tips out at about 2.5 tons. And yours has a W/F. But you have to be concerned with braking. I'd have to think that if you do it, once you're started, no stopping momentum until the top, because you sure would hate to get dragged backwards and... You certainly don't want to shove the clutch in going up hill, and then dump it. The M can lift the front end on its own without the help of a grade and the weight of the airstream. Is it flat where you're going to park it, or still on a grade? Are you going to turn it around if is still on a grade? At some point you're going to have to get off and chock some tires.
Be careful, very careful. Your only brakes are the throttle, whatever brakes the M has, and gears. That airstream is dead weight on wheels, and looking for somewhere to go, with or without, or over you. Don't want someone to post a link to a story in the paper about you.
Mark
Bob
05-02-2006 22:49:06
Pulling power isn't EVERYTHING... brakes are nice, too!
