Tractor Talk Discussion Forum
OT - Using gas line for water line
Dug
07-05-2006 16:44:22
I bought a house half finished and need to run water (1000 feet). The previous owner buried 2 gas lines in the same trench as the electric line. The gas lines are buried at 30 inches and the eletric is 48 inches. Can I use the gas line to run my water? The lines are 2 inch yellow flexible lines. It says "gas use only" but one of the contractors at the water department told me I could use it for water also.
doogdoog
07-06-2006 01:23:05
 Re: OT - Using gas line for water line in reply to Dug, 07-05-2006 16:44:22
Aloha, I would think that the 2" pipe would be like a snake under the ground and not level (straight). No way would you be able to run a 1" line thru it without hanging up especially for 700'. It would be easier and faster to run a new pipe.
Mahalo,
doogdoog
bill mar
07-05-2006 18:38:58
could you run the water line inside of the 2" gas line? just a thought.bill m.
Dug
07-05-2006 20:25:30
 Re: OT - Using gas line for water line in reply to bill mar, 07-05-2006 18:38:58
Bill,
That was plan #2. They buried two 2 inch gas lines side by side. I maybe able to pull/push a 1 inch line through each...split the main into two 1 inch lines, run them the length of the buried gas line, then join them together before taking it into the house.
The question is, can I push pull 700 feet of 1 inch line through? Is there a line flexible enough, like Pex? I doubt I could make it with rigid pipe.
SHeiserman
07-05-2006 17:54:21
What you do on your property is entirely up to you, but I wouldn't do it. See if the contractor can show you in writing where it's ok to use pipe marked for gas in a water (potable???)system. Even if it wasm't actually used for gas, I wouldn't think an inspector would let that fly. If it actually had gas run through it at one time, no way. Local plumbing supply house should be able to get you a definite answer also. It's no doubt a candy-a$$ liability issue.
Sid
07-05-2006 17:29:35
I would not risk it. What would happen if a few years down the road a repair is being made. "Hey Jake lets just tap into this one."
SH
07-05-2006 17:57:44
 Re: OT - Using gas line for water line in reply to Sid , 07-05-2006 17:29:35
Good point. Forgot PE is color coded for a reason.
Sid
07-05-2006 17:29:33
