Tractor Talk Discussion Forum
Stepped or Flat-top Pistons?
48C-MAN
08-02-2006 07:45:02
Getting ready to put the parts to the restoration of my grandfathers 48 Farmall C and was wondering if I should go with flat top or stepped head pistons? I have noticed that the price is almost the same.
Gary in Mozarks
08-02-2006 08:56:46
 Re: Stepped or Flat-top Pistons? in reply to 48C-MAN, 08-02-2006 07:45:02
what is the compression with the flat top pistons? something in the neighborhood of 6:1? From what I have read, most modern fuels (gas and or alcohol mixed) and do better with a little higher compression and you always have the option of backing off the timing a little if it gets warm makes it start easy too.
48C-MAN
08-02-2006 09:02:08
 Re: Stepped or Flat-top Pistons? in reply to Gary in Mozarks , 08-02-2006 08:56:46
Sounds like a good idea.
the tractor vet
08-02-2006 08:17:24
Go with the step head , go for all the power ya can get.
Mike M
08-02-2006 08:17:18
I overhauled one of those and was told that if I had the model without the water pump not to go to the high compression pistons or else overheating would become a problem.So if you have a water pump you may be able to use the high compression ones.
48C-MAN
08-02-2006 08:49:33
 Re: Stepped or Flat-top Pistons? in reply to Mike M, 08-02-2006 08:17:18
In regards to the overheating I was told to make sure that the head gasket is for a C and not a Super C due to the size of the coolant passages. They are smaller in the Super C because they have a water pump. I was also planning on running Engine Ice coolant after the rebuild to help dissapate the heat better.
