Tractor Talk Discussion Forum
Voltage problem--- Help
K.B. in Pa.
08-14-2006 14:28:00
I bought a IH 350U at an auction (so I have no idea about it's history) and it had a dead 8 volt battery in it. I looked at the tractor and it has a Gen. and a votage regulater and is pos. ground so I assumed the tractor was 6 volt.So I bought a new 6 volt battery. I've been starting to work on the tractor and moving it around and the battery keeps going down after 6-7 starts. I charge the battery and load test it and it is good. Check the tractor to see if it is charging and find out it is puting out 14.3 volts. a 6 volt gen. can't put out 14.3 volts can it?Or maybe is it a 12 volt gen.? How can I tell? Everyone I talked to says they never heard of a pos. ground gen. except one guy said they made them on some Euapean equipment. I don't have the tools here to fab. up bracets to hold an alternater, don't want to or have the money to spend right now to buy an alt. (why sould I what the heck the gen. is working right?)I cn't just put a 12 volt battery in it can I? So now what do I do?Any ideas? Thanks for the help ahead of time folks!
John T
08-14-2006 19:23:43
 Re: Voltage problem--- Help in reply to K.B. in Pa., 08-14-2006 14:28:00
KB, First of all a generator dont necessarily know what its voltage is supposed to be, its increased by turning it faster or passing more current througth its field windings. I have used 6 volt gennys to charge a 12 volt battery simply by changing to a 12 volt VR, its not perfect or engineering correct and it dont charge at any high rate, but it can work.
Next, a good battery sitting idle ought to read around 12.6 volts, but if hooked to a good working genny it ought to rise to 13 and 14 volt range, therefore, if your battery is doing that you probably have a 12 volt genny and a 12 volt VR or at least a 12 volt VR (on a 6 volt genny) and it sounds like all is well IF IT AINT BROKE DONT FIX IT.
Next, the output voltage of a genny unloaded and not connected to a battery really dont tell you all that much. Its voltage when connected to a battery is more valid for telling whats happening as noted above. If no load is present the voltage of a 12 or even a 6 volt genny can rise above the voltage of a battery so hooking a meter to it unloaded isnt much help.
Next a genny will work at EITHER pos or Neg ground provided its polarized and the VR is suitable and many old tractors used the Pos ground system
This is way more then you need but to save time I will copy n paste my standard troubleshooting procedure for non charging you can work through and post back your findings and any questions.
TROUBLESHOOTING CHARGING SYSTEMS
ARE YOU SURE THE AMMETER IS WIRED CORRECT AND WORKS????? If you turn the lights or ignition on (if coil ignition not a mag) when she’s not running, the ammeter should swing over to the - discharge direction, does yours??? Are BOTH the ammeter terminals reading hot battery voltage?? They MUST !!!!! ! There’s but one wire on the ammeters Supply (from battery/starter) terminal while its other Load terminal wires to the BAT terminal on a Cutout relay or VR PLUS wires to feed loads like lights or ignition, unless where a 4 terminal VR is used where lights n ignition are fed from the LOAD terminal on the VR.
To Polarize the Generator, first temporarily dead ground the Gens Field post to case/frame, then momentarily flash jump a wire from the Cutout Relay or VR's "BAT" terminal over to its GEN (or ARM) terminal and you ought to get a small spark. Same things accomplished by momentarily flash jumping a hot wire (BAT terminal on Cutout Relay or VR or starter post etc) direct to the Gens ARM post to get the spark.
TROUBLESHOOTING A CHARGING PROBLEM IN CLASS A DELCO TYPE SYSTEMS
1) For a good working Gen to get to and charge the battery, it has to have a path usually from the Gens ARM post,,,,, ,,,,to and through the Cutout Relay (between its GEN and BAT terminals, regardless if on a VR or Relay),,,,, ,,,up to the Load (NOT to battery) side of the Ammeter,,,,, ,,,to and through the Ammeter,,,,, ,,,,from BAT side of Ammeter to ungrounded battery terminal, often via the starter lug post. Is yours wired that way or equivalent ??? The ammeter should read hot battery voltage on BOTH terminals, does yours??? Even if an ammeter were stuck (but still continuous) as RPM increases the battery voltage should rise from 12.6 to near 14 volts and/or the lights glow brighter (half that on 6 volt systems). Have you tried that in case the ammeter isn’t working right?????
2) If the above is so, the BAT terminal on the VR or Cutout Relay MUST ALWAYS READ HOT BATTERY VOLTAGE. Does yours??? If not, the Gen cant get to and charge the battery.
3) The Gen to VR (if it has one) wiring is as follows:
BAT on VR to ammeters load (NOT battery) side
ARM (or GEN) on VR to Gens Armature post.
FLD on VR to Gens Field post.
(L) Load (if you have a 4 wire VR) up to BAT supply input terminal on switch to feed loads like lights and ignition.
WIRING ON CUTOUT RELAYS: They wire BAT side to ammeters Load terminal,,,,, GEN side to gens Armature post. On cutout relay systems, the Gens Field post is wired to the light switch where it gets a dead ground for high charge or a resistive ground for low charge. Therefore, there must be a good connection from the Gens Field post up to the switch PLUS the switch is good and it’s well grounded !!!!! !!
4. THE GEN AND VR OR CUTOUT RELAY MUST BE WELL GROUNDED AND THE BELT GOOD N TIGHT. If any doubt, run a ground wire from the grounded battery post or clean solid frame member direct to the Gen and see what happens????? ????? ????? ????? ????
NOW, if the Gen and VR are grounded,,,,,all is wired correct,,,,, ,,BAT terminal on VR or Cutout Relay is HOT,,,,, ,,Belt is tight,,,,, ,,,Ammeter is good n continuous n works but she wont charge, have you had the batteries tested lately????? Is there electrolyte above all the plates and no cells have a gray or milky appearance????? A bad battery may not accept a charge you know!!!!! !! If the battery checks okay, proceed below to see if its a Gen or VR problem (AFTER you have insured the wiring per the above)
TO DETERMINE IF ITS A GEN OR VR OR CUTOUT RELAY PROBLEM
5. a) VOLTAGE REGULATOR SYSTEM: With the tractor running, temporarily ground the Gens Field post to case. If she charges then but NOT otherwise, the VR may be bad, or a wires missing from VR's Field post to the Field terminal on the VR, or the VR isn’t well grounded.
b) IF IT’S A CUTOUT RELAY SYSTEM and she charges only if you dead ground the Field but NOT otherwise, its either a bad switch or the switch isn’t well grounded or else the wires bad or open from the Gens Field post up to the switch. INSURE THAT GOOD SWITCH GROUND AND WIRING
6. If she still don’t charge, leave the Field grounded and jump a wire across from the VR or Cutout Relays BAT terminal over to its GEN terminal (jump by passes the cutout relay) and see if she charges. If then but not otherwise, a VR's cutout relay isn’t working correct (maybe points burned/carboned) or a Cutout Relays NOT working or not wired correct.
7. With the 2 steps above, you have basically by passed the VR or Cutout relays functions, so if she still don’t charge, you're left with a bad battery or wiring or the Gen itself.
8. MOTOR TEST. You can Motor test the Gen. If its grounded and you remove the belt and apply hot battery voltage direct to its ARM Post and have the Field Post dead grounded to frame, it should motor n run well (Armature n Brushes and Commutator likely okay). Then, if you next remove the Fields ground and it speeds up some, the Fields probably good. If it passes both those tests, it should charge, and if not, it may be a wiring or battery or grounding problem. The hot battery voltage may be taken off the VR's BAT terminal or the starter post or the battery itself for this test.
9. Typical Gen problems may be the brushes are worn down or the hold down spring assemblies are stuck/corroded/dirty and arent pushing the brushes tight down against the commutator. Check those things out. Worse may be bad fields or armature etc. Air and WD 40 etc can clean and free them, the hold downs must be free n snap and hold the brushes DOWN TIGHT and they cant be worn down too low.
SUMMARY: Check the wiring,,,,,the grounds,,,,, insure BAT on VR or Relay is hot,,,,, ,check battery (maybe load tested and Specific Gravity checked),,,,, ,,,good tight belt,,,,, ,insure ammeter is continuous (BOTH sides HOT),,,,, see if battery voltage rises above 12.6 (half that for 6 volt system) and/or light glow brighter,,,,, ,,,do the Field and cutout relay VR by pass checks,,,,, ,,insure the Gens brushes arent worn down and the hold down springs are free n clean and push the brushes down tight,,,,, ,,,,,check the connections,,,,, ,,,try the Gen Motor Test to see if its good.
You may just have a bad battery or bad ground or connection if the Gen and VR or relay are okay. Good Luck n God Bless, let us all know.
John T Nordhoff in Indiana, retired electrical engineer who usually lurks over on the Mother Deere pages instead of over here on the "dark side" lol
K.B. in Pa.
08-14-2006 16:35:40
I just took some thinner and use it on the Gen. to help me see the numbers on it. The numbers that are stamped into the body of the Gen. are 1100531 and the numbers that are on the little football shaped tin plate that is ribited on are 11 0531 0m2 Can anyone tell me from looking at these numbers if this is a 12 volt or 6 volt gen.? Thanks!
John M
08-14-2006 17:52:03
 Re: Voltage problem--- Help in reply to K.B. in Pa., 08-14-2006 16:35:40
1100531 is a 6 volt generator. Its [possible that it was converted properly to 12 volt, or someone has put a 12 volt regualtor on it and turned up the generators output.
K.B. in Pa.
08-14-2006 16:16:04
Thanks RAB for the reply. Unfortunaly the Gen. reg. and the starter have all been painted over, a couple of times. I tried scraping off the paint but still can't read anything on them. I have just moved the tractor around here a little, proably haven't run it for more that 4 or 5 min. at a time, but I didn't notice the battery boiling over. There is only one light working and it is dim.
K.B. in Pa.
08-14-2006 15:57:40
Thanks for the reply Massey 333. Now I know my tractor is suppost to be a pos. ground. (Hey I never said those guys that gave me the bad information were my freinds ha ha.) I do know what the voltage is at the battery termanls,it is 14.3. Is that what a 12 volt gen. is suppost to put out? I will send away for a IT manual but I didn't want to wait the week or so until it comes to get an answer to my questions so I thought I would ask on here because there are a lot of knowagable folks here. I don't think I'm in trouble yet, am I?
massey333
08-14-2006 16:43:20
 Re: Voltage problem--- Help in reply to K.B. in Pa., 08-14-2006 15:57:40
I don't know where you are in Pa.,but any TSC or Farm supply store SHOULD have that I&T Manual for IHCs.use some Lacquer thinner or Turpentine to Maybe remove some of the paint.You may not be in trouble yet but your getting close.14.3 would be right for a 12V.Gen. Good Luck.
RAB
08-14-2006 15:52:56
Assuming, with old metal, is asking for trouble.
The generator (a/c or d/c) will have a voltage rating on it or a manufacturers serial number. If it doesn"t the regulator will. If you can"t find that, the light bulbs might give a clue. Failing that the starter motor may help if it is a 12 volter (many old tractors have been changed to a 12 volt system but retain the 6 volt starter)
If it is a dynamo it could easily be negative or positve ground. If it is an alternator it is almost certainly 12 volts and most likely negative earth.
How are you checking the output voltage? Across the battery? Volts is useless without currrent. A 6 volt d/c generator would likely give that voltage driven into an open circuit.
If your 6 volt battery is going dead it is not being charged. 12 volt charging into a 6 volt battery would very soon "boil" the battery - ie electrolyse the water in the electrolyte, overheat it and very shortly destroy it.
RAB
massey333
08-14-2006 15:05:47
First,You need to get some new friends(Experts)because 12V.Pos Grd.was a very Common Thing on farm equip and Const.equip.How do you know it is Pos.Grd.and not know What the Voltage is????The Gen.and Reg.will be Marked as What they are.A 350 of that era would almost be 12 Volt.GET a I&T Manual or a IHC service Manual before you go any Further and get in more Trouble than you already are.
