Tractor Talk Discussion Forum
Massy-Ferguson TO30 thrust shims
Okie Dokie
08-17-2006 13:57:15
I'm looking for the "shims" that fit inside of the "thrust washer" which is located behind the crankshaft timing gear and directly behind the "thrust plate" on my TO30. Seems I found mine in the oil pan mostly disintergrated and Massy doesn't make the part any longer or know where one may be had. I suppose if I had the old one I could have another machined but unfortunately I don't have that option. If anyone has any suggestions I'd sure appreciate it as the TO30 has been a good friend for a long long time.
Turke Bros. Farms
08-17-2006 18:47:45
 Re: Massy-Ferguson TO30 thrust shims in reply to Okie Dokie, 08-17-2006 13:57:15
I have them, how many? what size on the shims? do you need the brass nibs that hold it in place? 810-434-0108
Okie Dokie
08-17-2006 15:29:11
Great idea but unfortunately toooo late.
old art
08-17-2006 14:47:13
befor you take of the gear check how much end play ther is in the crank shaft by prying it back or forward and measure the space where this shim would be alow acouple of 1000s for clearence
