Tractor Talk Discussion Forum
Help ID Chev. Truck Engine
Earl-IL
08-29-2006 17:56:55
The number stamped on the machined pad on the front of engine is T-1106AHD Looking for block casting number .Will have to clean some more. Thanks if you can help. Earl
Gary in Mozarks
08-30-2006 04:36:15
 Re: Help ID Chev. Truck Engine in reply to Earl-IL, 08-29-2006 17:56:55
He is right about the casting number being on the rear of the block. Go to www.mortec.com and you will find all the numbers/years plus an explanation of how the system works G
Earl-IL
08-31-2006 12:04:42
 Re: Help ID Chev. Truck Engine in reply to Gary in Mozarks , 08-30-2006 04:36:15
Thanks for your help. Earl
2x4
08-29-2006 21:12:29
block casting number is on the engine at the "lip" where the transmission bolts on, on the drivers side, on top of the lip. May need a toothbrush to clean oil & gunk off the numbers (there will be no letters, tho some numbers may resemble letters). Probably will need someone to help you with flashlight & mirror as the firewall is very close to this area. 6 or 8 digit number depending on how recent engine was made.
Earl-IL
08-31-2006 12:06:14
 Re: Help ID Chev. Truck Engine in reply to 2x4, 08-29-2006 21:12:29
