Tractor Talk Discussion Forum
WD 45
Wild Bill Caldw
08-30-2006 17:03:08
I own three old tractors or maybe they own Me ,sometimes I'm not sure which.Farmall 1943A,Farmall 1953SuperA,International 240 utility. I'm lookin' at a Allis Chalmers WD45.Question is....What size Disc would be the ideal size for a WD45.I'll be truck patchin' 8 acres of good North Louisiana bottom land . No gumbo mud.
thanks,
Bill Caldwell
Craig in MO
08-31-2006 04:34:15
 Re: WD 45 in reply to Wild Bill Caldwell, 08-30-2006 17:03:08
I pull an old IH 10 foot with my WD (33HP) and it does ok. If I angle the gangs to the max I can sure tell and the WD chugs a bit but still pulls her. I have no fluid in the tires or rear weights of any kind so she will spin a bit on the uphill grades.
Wild Bill Caldwell
08-30-2006 18:34:37
Thank Yaw'l very much.I wouldn't have known the difference. Any thing else tricky I need to look out for? Other than all the usual things to look for in buyin' used?
Thanks'
Wild Bill
old
08-30-2006 18:52:40
 Re: WD 45 in reply to Wild Bill Caldwell, 08-30-2006 18:34:37
Make sure the hand clutch works good and give you live PTO. Also look close at the seat because the bushing wears and then it sort of flops side to side. Also look close at the lower area of the PTO, I've seen more then one that was cracked/broken in that area
Arlen(MN)
08-30-2006 17:43:40
It should handle an 8 ft. disc. It depends on the soil and moisture conditions.
old
08-30-2006 17:36:42
Well a WD-45 is rated at 43HP by the neb test, and the WD is 34HP. Big thing is to make sure that it is a WD or WD-45. The engine will fit in either tractor and if you don't know what to look at/for you can end up with a WD instead of a WD-45. If all you do is walk up to either they look pretty much the same. The WD-45 engine will not have a side plate on the right side of the engine but the WD will have a side plate that is bolted on. Either one will handle a 6 foot heavy disc well maybe a little more depending on how much weight you put on it
