Tractor Talk Discussion Forum
hydralic system
Ron Corkum
10-04-2006 17:58:09
A David Brown tractor with a front end loader has had one tilt cylider replaced and the dual hand control repaired.Now it is acting weard when the 3point is lifted full up the tilt will drop.
Is there an adjustment in the control to prevent this.It seems like oil is been drawn back.
Ron Corkum
Roy Suomi
10-04-2006 19:57:09
 Re: hydralic system in reply to Ron Corkum, 10-04-2006 17:58:09
I'd say you got a leak internally in the loader control valve..Once the circuit is closed , no oil should move there till the valve is moved..Does the valve spool center itself or does it stick in different positions??
