Tractor Talk Discussion Forum
Plug wires Ford 2000
Brian630
10-21-2006 10:54:19
I am replacing the plug wires on my Ford 2000 3 cyl. gas tractor. I forgot to mark them. Firing order is 1 - 2 - 3 and the rotor turns counter clockwise. Correct me if I'm wrong. First wire goes to #1 marked on dist cap and to the plug at front of tractor nearest the fan. Second wire to cap going counter cloclwise and to the middle plug (next one back from #1). The last one is a given. Thanks Brian
buickanddeere
10-21-2006 13:43:22
 Re: Plug wires Ford 2000 in reply to Brian630, 10-21-2006 10:54:19
If you didn't use solid core wires, may as well do the job over when you are at it.
Brian630
10-22-2006 16:47:29
 Re: Plug wires Ford 2000 in reply to buickanddeere, 10-21-2006 13:43:22
I used magstar gold - 7mm high performance s-4 stainless steal mag wire. Sparex brand. These are the only one I could find. Let me know if you know where I can get the ones you mention.
jmixigo
10-21-2006 11:33:21
I can't remember if that dist turns CW or CCW. With the cap off bump the starter and if CCW you rite. If it jus pops an backfires reverse 2-3.
3 cylinder motors make this simple.
Brian Egnasher
10-21-2006 11:42:46
 Re: Plug wires Ford 2000 in reply to jmixigo, 10-21-2006 11:33:21
thanks. work on that next after I get points and condensor out. pain in the butt. don't give you room to get in there.
