Tractor Talk Discussion Forum
O/T Movin' rocks
coflyboy
11-04-2006 14:30:08
I need to move rocks, railroad ties, bridge timbers, etc around in tight places where I can't get the tractor.
Since my back isn't so good any more I've been using a two wheel dolly. Works but leaves a lot to be desired. Is there a BTDT out there who has found a better way?
Kestrel
11-05-2006 08:16:22
 Re: O/T Movin' rocks in reply to coflyboy, 11-04-2006 14:30:08
third party image
I've built approx. 500' of stone wall on my property by hand, using only a two wheel dolly to transport stones unearthed from adjacent areas. I don't recommend this to any sane person but it's a hobby with me. If you do work in tight areas with rocks-get steel toe boots !! Kestrel
low budget
11-05-2006 03:35:50
Find someone younger stronger and prouder than you and tell them its too heavy for them to move!
2x4
11-04-2006 21:01:07
the skid steers with rubber tracks are unbeatable. Rent one from a Cat dealer or other serious construction rental yard.
old
11-04-2006 18:10:56
Need more info to be able to come up with ideas. I have the same problem as in I can by doctors orders lift 35 lbs so I have come up with a lot of ways to move a lot with out useing my back. What type of space are you talking about?/ How far do you have to move the stuff?? Are you moveing it to a place bigger or smaller?? ETc ETc???
coflyboy
11-05-2006 07:22:56
 Re: O/T Movin' rocks in reply to old, 11-04-2006 18:10:56
Thanks to all who are trying to help. I'm building terraces, 30 to 60 feet long, on the side of a mountain. It's quite steep. Using the tractor I can load materials on the terraces from the bottom or the top. The terraces are three to seven feet wide with trees etc. in the way, so there is no room to manuever. As I said I'm using a 2-wheel dolly but that is so frustrating I usually do something stupid and am laid up for a couple of days.
By the 'tone' of this forum I suspected there would be a few BTDTs out there. Again thanks.
old
11-05-2006 07:29:44
 Re: O/T Movin' rocks in reply to coflyboy, 11-05-2006 07:22:56
Sounds like you need something like a backhoe or one of those mini excavators. Either one would get what your doing done and save your back
JOHN HARMON
11-04-2006 15:54:16
I use my 4 wheel drive Arctic Cat ATV and a Agrifab Trailer I added some length to the Bed on for such work. It has it's limitations but it saves a lot on my 70 year old back. John
Rod in Smiths Falls, ON,
11-04-2006 15:36:01
Golf cart with a narrow, low trailer.
It's almost as manoeuvrable as a wheel barrow and much stronger.
730virgil
11-04-2006 14:35:20
can you get a skid loader there ? or maybe loader on garden tractor ?
kyhayman
11-04-2006 16:13:23
 Re: O/T Movin' rocks in reply to 730virgil, 11-04-2006 14:35:20
Skid loader is my pick, most versatile thing Ive got on the farm.
