Tractor Talk Discussion Forum
M W hydraulic
sshev
11-22-2006 10:31:10
I"d like to add hydraulics to a B farmall. I have an opportunity to purchase a M&W set-up that replaces the magento with a vertically mounted distributor which also drives the hyd. pump. This system is currently on an M. My question is will this work on a B too? Is the governor housing and drive coupling the same on the M and the B? If so, anyone see why this wouldn"t work?
thanks,
Scott
trulyred
11-22-2006 14:40:49
 Re: M W hydraulic in reply to sshev, 11-22-2006 10:31:10
I ran that setup on an "A" for the lift on the belly mower and a front mount blade I rigged on the front, worked great with no problems. I mounted a long cylinder at the bellhousing and used it for both the mower and the blade.
Nebraska Cowman
11-22-2006 10:45:50
Yes, I've seen that type. It should interchange with any flange mount magneto. The only limiting factor would be the drive gears on your B but after all these years the pump is probably not putting out it's original pressure and might be fine.
