Tractor Talk Discussion Forum
M-F 220
Big Mike
12-04-2006 17:18:02
Diesel. Lost power, blew black smoke, then just DIED! Bad Rings, er Valve /Head Prollums?????
mowr
12-04-2006 18:18:59
 Re: M-F 220 in reply to Big Mike, 12-04-2006 17:18:02
Start with the easiest stuff first. Blocked intake? Clogged/collapsed air filter? Something get sucked in (shop rag, paper towel)? Engine shutdown choke valve come loose or cable to it slipped?
Big Mike
12-05-2006 04:49:28
 Re: M-F 220 in reply to mowr, 12-04-2006 18:18:59
Very Low compression. Didn't actually check it, but you can turn the motor over easily by hand. She's a '81. (Or thereabouts) That's why I suspect stuck/bad/out of adjustment valves or worn rings. The air filter intake was clear.
