Tractor Talk Discussion Forum
Im Stuck
John T
12-06-2006 08:16:38
Im STUCK and I absolutely Hate it When That Happens GRRRRR RRRRR RRRRR RRRRR R
For like 3 years Ive fed big round hay bales in the same area using my lil utility wide front but fully weighted with tire fluid n 4 wheel weights AC D-15 and did fine, but I just fed n went to pick up the feeder (use front loader) n a front tire got down in a hole n it simply will nottttt tttt come out grrrrr rrrrr rrrr as its froze just enough the rear tires just slip on top the ground, no bite n she wont rock out.
Guess I gotta (bad I I hate to) call my buddy Henry who will bring a 720 or Bens Four Hundred Two, Zero n drag me out, gotta love it right????? ? I had surgery a few weeks ago n still cant lift or tug a lot but it needs a tractor to ease it out, no lifting or tugging actually required
A stuck John T, Oh Well such is the farm
VADAVE
12-06-2006 08:44:50
 Re: Im Stuck in reply to John T, 12-06-2006 08:16:38
Won't your front loader lift the front of the tractor?
Put the cutting edge straight down lift the front end and roll the bucket.
old
12-06-2006 08:35:12
Well if your loader has power down then just roll the bucket till the lip is down and the roll it back at the same time your backing up with the tractor. Of course if you don't have power down it will not work. BTDT more then once. I even one time turned my backhoe 180 becuse I had it stuck down to the axles and I was the only one around took me about 2 hours but it came out on its own
John T
12-06-2006 08:58:25
 Re: Im Stuck in reply to old, 12-06-2006 08:35:12
Unfortunately, NO power down on the bucket grrrrr rr
John T
old
12-06-2006 09:13:33
 Re: Im Stuck in reply to John T, 12-06-2006 08:58:25
Another way but not near as safe to do is use a chain and some anchor point and hook it up so you can roll the bucket and lift the arms to pull your self forward but you can also pull your self on your side if not real careful doing it that way.
John T
12-06-2006 11:07:32
 Re: Im Stuck in reply to old, 12-06-2006 09:13:33
IM FREE lol We jacked up the front axle one side at a time n got a big oak 2 x 6 under each front wheel n that was all it took. No big deal but I simply hate to be stuck and especialy when I dont feel well enough to fix it without callin for help.
John T
John S-B
12-06-2006 14:39:01
 Re: Im Stuck in reply to John T, 12-06-2006 11:07:32
John I posted some pics it the stuck and troubled forum. That's exactly how I got my Farmall M unstuck. Just an 8 ton bottle jack and some scrap wood. I never throw away 4x4's or 2x6 or wider stuff, I can always use it for cribbing.
