Tractor Talk Discussion Forum
Question for Allan on 66 series
old fashioned f
01-14-2007 11:47:31
Howdy Allan,
Since you"re fast becoming the expert on 66 series Internationals I thought I"d get your input on a possible upcoming job. One of our customers found out that I paint tractors and now wants me to paint his 1466. First off, I am kinda doubtful that I"ll be able to get it in the shop due to its height. Anyway, if I do find a way, how much of a job is it to paint one of these 66 series tractors? I"ve done old ones up to now and just wonder what kind of hornets nest I"m gonna get into here. Thank ya sir. God bless.
--old fashioned farmer
Allan In NE
01-14-2007 12:08:52
 Re: Question for Allan on 66 series in reply to old fashioned farmer, 01-14-2007 11:47:31
Make no mistake, I'm no expert at anything. :>(
Your paintjob is a walk in the park if the tractor doesn't have a cab.
Pull the trim panels and seat, put the tractor on 4 jack stands, pull the wheels all the way around and throw paint at it.
If the tractor has a cab then you'll end up with grey hair like me, as it's gotta come clear off of there. :>(
Allan
01-14-2007 12:30:02
 Re: Question for Allan on 66 series in reply to Allan In NE, 01-14-2007 12:08:52
third party image
Here's a look at the one I'm currently working on but on this one I'm doing all the seals and gaskets too. This picture is before I took the engine out. God bless.
trw
01-14-2007 17:52:35
 Re: Question for Allan on 66 series in reply to old fashioned farmer, 01-14-2007 12:30:02
Looks exactly like the one that I am working on, except that I have the rear apart. I got the engine running last winter, and now I am replacing the seals in the rearend and getting it cleaned up. How serious do you get when you are getting the "cast" pieces,(i.e. torque tube, transmission/rearend housing, etc.), ready to paint? I can't get any of this down to bare metal with a wire brush on a grinder, but I can get all the rust and loose paint off. Is this going to be good enough to get a decent paint job?
01-14-2007 19:12:20
 Re: Question for Allan on 66 series in reply to trw, 01-14-2007 17:52:35
Howdy,
It should be alright as long as you've got the majority of that good stuff off. I just prefer to have it as clean as I can. To me that's a personal preference. I do run through several wire brush wheels this way though. It also adds time to the project. The main thing is to get a smooth surface. If you cut off a good bit of the external grime, grease, and surface rust but leave paint on it so that you can see edges of where the old paint ends and bare cast begins, I'm talking a well-defined edge, then I'd go further. If it's a well blended look then you're alright. If you leave that defined edge you'll see it under your final coat even and it will kill the whole thing. God bless.
JOE ZIP
01-14-2007 13:54:05
OH! NO! I can hear the CONCRETE BLOCK argument from here!!!!!
01-14-2007 19:16:17
 Re: Question for Allan on 66 series in reply to JOE ZIP, 01-14-2007 13:54:05
Ha ha. I know what you're saying but don't worry. That was a very quick fix to free up the big wood blocks that were holding it. I needed those plus the engine hoist back when I was replacing the rear tires on my JD R. It didn't have to sit like that long. God bless.
p.s. I don't like to use blocks either. If you can drop it on the floor and watch pieces fly then it doesn't need to be holding up a piece of equipment weighing almost a ton.
PatMz
01-15-2007 09:53:02
 Re: Question for Allan on 66 series in reply to old fashioned farmer, 01-14-2007 19:16:17
Just roll those blocks 90 degrees so the holes go up and down. Plenty of strength for holding up a tractor. But, like you said, don't drop anything on them!
